Hi all,
I come in desperation and hope that someone can help me with my PC! The CPU temps on the PC idle in the 60s and 70s most of the time, sometimes (but rarely) gets down to the 50s. I've had the issue since I built the PC at the end of last year, and I don't think it's manifesting as any actual problems that I've noticed - no crashes or anything like that - other than leaving performance on the table and probably not being healthy for the components. As I am typing this my room temperature is around 23°, but the CPU is ranging from 75 - 81°.
I've tried swapping out many components and sent others away for the manufacturer to test, tried Asus support (as the motherboard manufacturer - I thought it must be a BIOS setting problem) but they were pretty useless, and I'm out of ideas. Hoping someone can help.
Specs: Ryzen 9 5950X, Asus Dark Hero motherboard, 64GB Corsair Vengeance RGB, Asus TUF GTX 3090 OC, NZXT Kraken Z53 cooler (had a Corsair H115i Pro XT in there for the first 3 months - same issue), Be Quiet Straight Power 11 1200W, some SSDs and HDDs - full list here: https://uk.pcpartpicker.com/user/cemerson/saved/fwQnTW
Things I've tried:
  • Replaced the cooler (both 240mm AIOs). No change.
  • Sent back the CPU to Scan UK where I bought it, thinking it must be that. They tested it on an MSI Tomahawk motherboard with the AMD stock cooler and saw idles in the 30s, stress test didn't go above 40s. They sent it back, but weren't able to tell me anything about BIOS settings they tested under.
  • Had the opportinuty to swap out the motherboard for another Dark Hero. Did so, but nothing changed. Am back to the original one again now. Both were on the latest BIOS when I did this (couple of months ago now).
  • I update my BIOS regularly and am on the latest version (3801)
  • I've checked for obvious things like thermal paste application (I reapply Noctua NH-T1 each time I've had the need to, and there's no plastic cover on the cooler coldplate...)
GPU temps are fine and there are plenty of fans in my case so I don't think it's an airflow issue.
I run Windows 10 Pro 64 bit. Current version is 21H1 but none of the updates since I built the PC have affected the issue. Temperatures are high in BIOS too when idle so I don't think the OS is doing anything here. I'm convinced it must be some BIOS trickery I'm using or not using (PBO is off - should I be using that?), but I have no idea. Can anyone help?
Thank you!
https://linustechtips.com/topic/1380534-pc-running-abnormally-hot/
What is your CPU voltage set to in BIOS? It almost sounds like it's auto-applying a very high voltage, or you have one set manually high by accident. Higher voltage with no other changes will still make your temps skyrocket. Just a possibility though.
Primary Gaming Rig:
Ryzen 5 5600 CPU, Gigabyte B450 I AORUS PRO WIFI mITX motherboard, PNY XLR8 16GB (2x8GB) DDR4-3200 CL16 RAM, Mushkin PILOT 500GB SSD (boot), Corsair Force 3 480GB SSD (games), XFX RX 5700 8GB GPU, Fractal Design Node 202 HTPC Case, Corsair SF 450 W 80+ Gold SFX PSU, Windows 11 Pro, Dell S2719DGF 27.0" 2560x1440 155 Hz Monitor, Corsair K68 RGB Wired Gaming Keyboard (MX Brown), Logitech G900 CHAOS SPECTRUM Wireless Mouse, Logitech G533 Headset
HTPC/Gaming Rig:
Ryzen 7 3700X CPU, ASRock B450M Pro4 mATX Motherboard, ADATA XPG GAMMIX D20 16GB (2x8GB) DDR4-3200 CL16 RAM, Mushkin PILOT 1TB SSD (boot), 2x Seagate BarraCuda 1 TB 3.5" HDD (data), Seagate BarraCuda 4 TB 3.5" HDD (DVR), PowerColor RX VEGA 56 8GB GPU, Fractal Design Node 804 mATX Case, Cooler Master MasterWatt 550 W 80+ Bronze Semi-modular ATX PSU, Silverstone SST-SOB02 Blu-Ray Writer, Windows 11 Pro, Logitech K400 Plus Keyboard, Corsair K63 Lapboard Combo (MX Red w/Blue LED), Logitech G603 Wireless Mouse, Kingston HyperX Cloud Stinger Headset, HAUPPAUGE WinTV-quadHD TV Tuner, Samsung 65RU9000 TV
Welcome to the forums!!!
How is your CPU spread when you remove the CPU cooler??? What method are you using??
This sounds like improper mounting on the CPU cooler.
CPU Cooler Tier List  || Motherboard VRMs Tier List || Motherboard Beep & POST Codes || Graphics Card Tier List || PSU Tier List
Main System Specifications:
CPU: AMD Ryzen 9 5950X ||  CPU Cooler: Noctua NH-D15 Air Cooler ||  RAM: Corsair Vengeance LPX 32GB(4x8GB) DDR4-3600 CL18  ||  Mobo: ASUS ROG Crosshair VIII Dark Hero X570  ||  SSD: Samsung 970 EVO 1TB M.2-2280 Boot Drive/Some Games)  ||  HDD: 2X Western Digital Caviar Blue 1TB(Game Drive)  ||  GPU: ASUS TUF Gaming RX 6900XT  ||  PSU: EVGA P2 1600W  ||  Case: Corsair 5000D Airflow  ||  Mouse: Logitech G502 Hero SE RGB  ||  Keyboard: Logitech G513 Carbon RGB with GX Blue Clicky Switches  ||  Mouse Pad: MAINGEAR ASSIST XL ||  Monitor: ASUS TUF Gaming VG34VQL1B 34"
The thermal paste spread is fine - I've used a small pea sized blob in the middle of the CPU, have remounted several times and the spread has always covered the whole CPU without too much excess. The old cooler used the horrible AM4 mounting system but I did try to remount it when I realised I was having these issues and made sure to apply even pressure to both sides, even counting the number of times I turned the screwdriver for that. The newer cooler has a much nicer mounting system, using a backplate and standoffs, and again have mounted it several times, each time making sure I've applied even pressure on all corners.
As for BIOS voltage settings - I did check this and didn't find anything abnormal. I'll have to check the exact number and post back but HWInfo doesn't show anything particularly high, 1.35V rings a bell. I will check the exact figures and post back, though I loaded optimised defaults and haven't touched the voltage settings since setting up / last updating the BIOS. The things I have changed in BIOS are to turn CPU virtualisation support on, DOCP profile for the memory, resize BAR, (+above 4G decoding), and some fan curves.
Attached some photos of my BIOS settings. Sorry for the potato shots! I've built computers for a long time but never gone too far into the detail of all these settings (and the knowledge I do have is well out of date anyway), but maybe these can provide a clue to someone?
  • 3 months later...
