Quote
Total supports 1 x M.2 slots and 4 x SATA 6Gb/s ports
Intel® H410 Chipset :
1 x M.2 Socket 3, with M Key, type 2242/2260/2280 storage devices support (SATA & PCIE 3.0 X2 mode)*1
4 x SATA 6Gb/s port(s)
Corps aren't your friends. "Bottleneck calculators" are BS. Only suckers buy based on brand. It's your PC, do what makes you happy.  If your build meets your needs, you don't need anyone else to "rate" it for you. And talking about being part of a "master race" is cringe. Watch this space for further truths people need to hear.
https://linustechtips.com/topic/1380297-need-help-plz/#findComment-15040602
I was going to ask, "What does it say in the manual...?
**I frequently edit any posts you may quote; please check for anything I 'may' have amended.**
Current PC spec. in my profile.
Can I realistically call myself a gamer, if I only play ONE, twenty year old game...?
Did you test boot it, before you built in into the case?
WHY NOT...?!
https://linustechtips.com/topic/1380297-need-help-plz/#findComment-15040605
<-- Moved to CPUs, Motherboards, and Memory -->
Please ensure you're selecting the appropriate subforum for your question/post.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/1380297-need-help-plz/#findComment-15040613
Just now, jpmm_7 said:
dont have it it was prebiult
WHY NOT...?!
https://linustechtips.com/topic/1380297-need-help-plz/#findComment-15040616
You could have looked up the motherboard manual online....it's....on their website.
Current Build
AMD Ryzen 2600
Stock cooler
Asus ROG B450f gaming Mobo
1tb SKHynix m.2
WD 1TB HDD
Asus ROG Strix RX 5700xt
Thermaltake Toughpower 650w DPS RGB 80+Gold
16 Gigs ddr4 3000 gskill ram
Phantek fans
Phanteks P400TG
Laptop
Eluktronics Prometheus XVII
Ryzen 7 5800h
32 gigs ddr4 Corsair ram
Nvidia rtx 3080 max-p
17.3 qhd 165 hrz screen
1tb Samsung m.2
1tb WD black m.2
https://linustechtips.com/topic/1380297-need-help-plz/#findComment-15040626
