I've got an interesting issue with my Gigabyte R9 280x and I can't figure out what's wrong! I've attached a picture which shows the issue. As you can see in the mentio ed picture is the GPU load acting very strange. It used to be a lot more stable and consistent. This causes fps drops and is very annoying so if anyone have any clue to what's wrong please post an answer.
BR
post-70130-0-48716100-1397058621_thumb.p
https://linustechtips.com/topic/137617-issue-with-r9-280x/
Looks to me like a card that's thermal throttling. Have you checked the CCC settings under overdrive? Or do you have a custom fan profile running? If so give the fanspeed a little bump and retest.
Also what temps are your CPU at this point as is it OC'd?
Quack 🦆
https://linustechtips.com/topic/137617-issue-with-r9-280x/#findComment-1828535
i've tested with full fan speed (noisy!!) but issue persist. also tested different drivers, upgraded to win 8 from 7. What's the most strange part is that the CPU temp seem affected by this more than the GPU temp.
My setup:
Asus M5A78L-M/USB3
AMD FX-8120 X8 3,1GHz Black Edition
Antec VP550P 550W
Corsair 8GB (2x4096MB) CL9 1600Mhz VENGEANCE LP
Gigabyte R9 280x
Samsung SSD 250GB
CoolerMaster Seidon 120
https://linustechtips.com/topic/137617-issue-with-r9-280x/#findComment-1828580
