New Sound Card?
Go to solution Solved by Jaybird,
I think you are fine. most people here will say to stay with onboard audio if you arent running anything top grade.
Hello all, I currently have a creative fatal1ty sound card that I purchased roughly 4-5 years ago. I believe it is this card or very similar to this one(not at home cannot look at exact model)
http://www.newegg.com/Product/Product.aspx?Item=N82E16829102019
I currently have these speakers set for day to day movies, relaxed gaming, ect..  not super great speakers but not bad either..
http://www.newegg.com/Product/Product.aspx?Item=N82E16836121126
And i have this headset for more serious gaming/mic use.. also use it for all of my gaming consoles (ps4,ps3,360)
http://www.newegg.com/Product/Product.aspx?Item=N82E16868993004
I guess what I am asking is, should i look into a new sound card or speakers. I just got the headset a few months ago so i don't want to replace it.
Also if i should get a new sound card, what are good recommendations. I head asus xonar it pretty good but im not audio expert.
The other question i have is, is a sound card that much better than on board ( i know it depends on the mobo also so ill list system specs here)
Please let me know what you guys think
SYSTEM SPECS,
intel i7 4770k
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116901
ASUS Maximus vi extreme
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131974
G SKILL ripjaws z series 16 gb  4x4
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231501
antec 1300 plat psu
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371064
EVGA GTX 780ti superclocked
http://www.newegg.com/Product/Product.aspx?Item=N82E16814487001
samsung 840 pro ssd 240gb
seagate 2 tb drive 7200 rpm
https://linustechtips.com/topic/137609-new-sound-card/
CM Storm Switch Tester MOD (In-Progress) - http://linustechtips.com/main/topic/409147-cm-storm-switch-tester-macro-mod/
       Ammo Can Speaker 02 (Completed) - http://linustechtips.com/main/topic/283826-ammo-can-speakers-02/       A/B Switch V 0.5 (Completed) - http://linustechtips.com/main/topic/362417-ab-switch-v0
     Build 01 - The Life of a Prodigy -  http://linustechtips.com/main/topic/13103-build-01-the-life-of-a-prodigy/             Build 02 - Silent Server 3000 - http://linustechtips.com/main/topic/116670-build-02-silent-server-3000/
https://linustechtips.com/topic/137609-new-sound-card/#findComment-1828459
sound card are technically designed for computers that do not have onboard audio. they generally are not constructed for audio-philes simply becuase the card is limited on size.
https://linustechtips.com/topic/137609-new-sound-card/#findComment-1828666
Is the headset bad? seems to be pretty good to me, i know there are tons of better ones if i was super into sound headset wise.
I mainly got it because i can use it for anything from mobile to pc and consoles, and i like to be able to change presets and stuff. also the headset does simulated surround so i have it connected with optical or Dolby digital 5.1 with all my equipment.
mainly the sound card would be for if i wanted more of a  home theater experience when not using the headset.. such as 7.1 surround for movies and maybe immerse games and music if ya know what i mean.
sorry if my explanations are not the clearest.
https://linustechtips.com/topic/137609-new-sound-card/#findComment-1828678
