Help finding new case for MASSIVE GPU.
VectorTech
Go to solution Solved by Zmimgo,
Hey guys so I won the opportunity to buy a Gigabyte RTX 3080ti AORUS XTREME (four slot GPU) off of the NewEgg shuffle- the issue being my case the Lian Li TU150 (mini itx case) only supports three slot graphics cards. I still have about a month before I'm actually reunited with my PC (currently deployed) to figure all this out, and I may settle on getting bottom of my case laser cut out to support the GPU but I was wondering if anyone had any recommendations for any SMALL cases that will support a 4 slot GPU.
Thanks in advance!
PCPartPicker list for those interested.
https://pcpartpicker.com/list/vzTVMv
Data Systems Administrator | Sergeant - US Marine Corps | CCNA / SEC+
Ryzen 9 5950x | 64 GB DDR4 3600Mhz | Gigabyte RTX 3080 Ti | Full Build Info | HomeLab Setup
Congrats, waiting for my own to be dispatched by Amazon.
I had a similar issue, but more in terms of length, and thus decided to just go with a generic mid tower.
Did you consider case modification (ie "hot rodding" it) or custom water cooling?
Current system. CPU: AMD Ryzen 7 5800X; MoBo: Gigabyte X570S Aorus Master; RAM: 2x Crucial Ballistix MAX 2x8 GB (BLM2K8G40C18U4B); GPU: RX 6900 XT Gigabyte Aorus Master; case: Fractal Design Meshify-2; Storage: Samsung 980PRO 1TB NVMe SSD + 2x Samsung 980 1TB NVMe SSD; PSU: Seasonic Focus GX-850; Cooling: Arctic Liquid Freezer II 360.
I don't wanna mess with the front panel just cause I like my PC to be understated and kinda hidden and while water cooling is cool and all the cooler on that GPU is SO bad ass that it would be absurd to replace it with a waterblock.
On the "understated" note - what do you think about doing a "sleeper" PC? There were some cool builds by Linus&co.
