Power supply cables
Go to solution Solved by minibois,
Motherboard: 24 pin ATX and 8 pin EPS.
Graphics card: 2x (6+2 pin) PCIE
The 24 pin can be recognized by just having the most pins. The 20+4 pin part goes into your motherboard, the side with more pins in the PSU.
The 8 pin EPS and 6+2 pin PCIe can be recognized by seeing which one has two loose pins (which can be clipped together to go into the PSU). Usually it will have a marking on it too, like "CPU" for the former and "GPU"/"PCIE" for the latter.
With high power graphics cards, it is recommended to use two separate cables for the graphics card's 6+2 pin PCIE connectors.
So you need four cables:
- 24 pin ATX
- 8 pin EPS/CPU
- GPU power: two separate cables, which go from the PSU to one of the power plugs on the GPU.
- 24 pin ATX
- 8 pin EPS/CPU
https://linustechtips.com/topic/1374620-power-supply-cables/#findComment-15000285
- 24 pin ATX
- 8 pin EPS/CPU
Yep, that should be it. Dont forget to plug in other cables like fan-cables and case-cables for the power button etc.
https://linustechtips.com/topic/1374620-power-supply-cables/#findComment-15000292
- 24 pin ATX
- 8 pin EPS/CPU
thanks a ton dude, i was soo lost
https://linustechtips.com/topic/1374620-power-supply-cables/#findComment-15000299
