Hello all,
2 months back my PC suddenly went in to BSOD loop and kept on restarting itself, I was unable to enter in to safe mode or install a fresh copy of OS as the PC kept on restarting itself after the motherboard logo screen. So I knew it was a hardware issue ,So I gave my CORSAIR 16GB x 2 Ram sticks and my Gigabyte 1TB Aorus NVME gen.4 SSD to RMA. It seems that both of them were an issue so they replaced both of them. I installed the replacement ram sticks and SSD to my pc, installed new OS and everything worked fine for 2 months. But today again my PC crashed and went in to the same state where it restarts itself again and again. Again the suspect is RAM and SSD, can anyone help me what could be causing this problem? I am tired of going to the service center again and giving these two things to RMA again and again. Even if they replace with a new ones, this problem still persists.
Below are the Error codes i see in reboot loop:
IRQL_NOT_LESS_OR_EQUAL
CRITICAL_PROCESS_DIED
STOP CODE 0xc000021a
PROCESS1 INITIALIZATION FAILED
Below is my PC SPEC.
AMD RYZEN 5800X 8 CORE CPU
AORUS RTX 3080 MASTER 10GB GPU
RAM 32GB CORSAIR CMW32GX4M2C3200C16
GIGABYTE X570 AORUS PRO WIFI MOTHERBOARD
AORUS 1TB GEN4 AG41TB SSD
AORUS 360MM AIO COOLER
ROG HELIOS PC CASE
NZXT C850 80+ GOLD FULLY MODULAR PSU
https://linustechtips.com/topic/1374340-pc-bsod-issue/
Insert your OS installation media, USB flash drive I assume and try system repair. If it doesn't help  re-install windows.
It's hard to kill SSD in 2 months, but easy to mess up windows installation. You must keep pressing a key like "Esc" or "Function number key"  that works  on your computer to enter boot selection, not SSD, but external USB.
https://linustechtips.com/topic/1374340-pc-bsod-issue/#findComment-14998551
it doesn't work, when windows installation menu appears and as soon as i select install windows 64bit , it suddenly shows Blue screen and restarts. So this makes me unable to install OS unless i remove the affected RAM and SSD. The main question is what is causing my RAM and SSD to fail again and again?
https://linustechtips.com/topic/1374340-pc-bsod-issue/#findComment-14998560
