lan Dlan slower than expected
Solved by Oshino Shinobu,
Looks like it's one of the Powerline adapters that is what I'd consider a scam.
They say 1000Mbps everywhere, but the actual ethernet ports it uses are only 10/100, so max out at 100Mbps regardless of how much data they can move over powerline.
Provided it's this one, they use 10/100 Ethernet ports https://www.devolo.co.uk/fileadmin/Web-Content/DE/products/hnw/dlan-1000-duo-powerline/documents/en/Datasheet_dLAN_1000_duo__en_UK.pdf
