motherboard not detecting rgb
golde
I'm trying to plug in my 3 way splitter (cooler master) to my motherboard directly (without a controller) to see if it would work with RGB Fusion.
It's not being detected by any of my rgb headers on my motherboard.
cool story wish i new more...
Corsair Lian Li Bykski Barrow thermaltake nzxt aquacomputer 5v argb pin out guide + argb info
5v device to 12v mb header
Odds and Sods Argb Rgb Links
Try one of your RGB things first to see if the RGB is being detected, after that try with the splitter. Also, make sure you connect them correctly. If you use normal 4pin RGB then you need to line up the arrows the correct way.
It's an obvious question, but, do you have anything attached to the splitter?
Quote
RGB Fusion
Big oof. have you tried RGB components without the splitter? RGB Fusion is hot garbage, and it just doesn't work for a pretty good percentage of people.
