Quick question: Helios 300 or Legion 5 pro?
Solved by jaslion,
1 minute ago, Newblesse Obblige said:He is going for the modest 3060 option and don't care either Intel or AMD. I prefer the general comparison like thermals, built quality and etc.
Well simply put the lenovo legion 5 is superior here. BUT YOU NEED TO GET THE AMD VERSION. It is cheaper and just plain better in every aspect.
The helios 300 is not a bad laptop but the legion 5 pro amd ryzen version just plain up is better in every aspect.
