Budget (including currency): 500 USD
Country: USA
Games, programs or workloads that it will be used for: FPS games, YouTube, games, school
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): I just need a pc for 500 USD since I dont have much to spend on a PC. Thanks for your help. (it is ok if you go over 500, just not by a lot please)
https://linustechtips.com/topic/1371029-help/
PCPartPicker Part List: https://pcpartpicker.com/list/srLyGq
CPU: AMD Ryzen 5 5600G 3.9 GHz 6-Core Processor  ($258.98 @ Amazon)
Motherboard: Asus PRIME A520M-K Micro ATX AM4 Motherboard  ($69.98 @ Amazon)
Memory: ADATA XPG Z1 16 GB (2 x 8 GB) DDR4-3000 CL16 Memory  ($59.99 @ Amazon)
Storage: Samsung 980 500 GB M.2-2280 NVME Solid State Drive  ($59.99 @ Amazon)
Case: Cooler Master MasterBox Q300L MicroATX Mini Tower Case  ($49.99 @ Amazon)
Power Supply: EVGA GD (2019) 500 W 80+ Gold Certified ATX Power Supply  ($44.99 @ Amazon)
Total: $543.92
Generated by PCPartPicker 2021-09-05 23:35 EDT-0400
https://linustechtips.com/topic/1371029-help/#findComment-14973928
https://pcpartpicker.com/list/vwMF7X
Here is a best overall option for you.
High speed RAM is necessary for this iGPU to run well, So skipping on it would affect performance. Yes, it's 600 USD, If you don't have this much let me know and I'll make it little lower, But this is best you can buy in this price range. The case is good looking and have normal airflow, you can't really go any cheaper than that. It have one rear fan and you'll mount extra 2 fan in front as intake. That's all you need to cool this system.
I would really advise against going with cheapo RAMs, But CL16 3200 Will be also okey if u want to save 10-15 USD.
https://linustechtips.com/topic/1371029-help/#findComment-14974219
Motherboard: ASRock B450M Pro4 Micro ATX AM4 Motherboard  ($78.59 @ Amazon)
Memory: Silicon Power XPOWER Turbine 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  ($59.99 @ Amazon)
Storage: Klevv CRAS C710 512 GB M.2-2280 NVME Solid State Drive  ($47.99 @ Amazon)
Case: DIYPC MA08 MicroATX Mini Tower Case  ($36.92 @ Newegg)
Power Supply: EVGA BQ 500 W 80+ Bronze Certified Semi-modular ATX Power Supply  ($39.99 @ Newegg)
Total: $522.46
Generated by PCPartPicker 2021-09-06 08:40 EDT-0400
Get a B450M-A II or DS3H if you must get it down to $500.
https://linustechtips.com/topic/1371029-help/#findComment-14974598
