I go to bios then changed the ram timings of my ram and changed volts and frequency then when i save changes it wont start it just show black screen it doesnt show like press f2 or f11 thingy when i try to start my pc pls help i use it in my online classes tomorrow.
https://linustechtips.com/topic/1370765-help/
Reset CMOS.
Corps aren't your friends. "Bottleneck calculators" are BS. Only suckers buy based on brand. It's your PC, do what makes you happy.  If your build meets your needs, you don't need anyone else to "rate" it for you. And talking about being part of a "master race" is cringe. Watch this space for further truths people need to hear.
https://linustechtips.com/topic/1370765-help/#findComment-14972135
First, I do not suggest just changing things in your BIOS if you don't know what you're changing without at least basic knowledge on how to revert if something goes wrong. You didn't really give any specifics on what you were changing your RAM settings to so I'm going to assume you just randomly adjusted things? Why?
Reset your CMOS.
Ryzen 7 7800x3D -  Asus RTX4090 TUF OC- Asrock X670E Taichi - 32GB DDR5-6000CL30 - SuperFlower 1000W - Fractal Torrent - Assassin IV - 42" LG C2 - Windows 11 Pro
https://linustechtips.com/topic/1370765-help/#findComment-14972137
Reset your BIOS by clearing the CMOS on your motherboard. Consult your motherboard manual for instructions.
Desktop: KiRaShi-Intel-2022 (i5-12600K, 5060 Ti) Mobile: Moto Razr 50 Ultra (Razr+ 2024) | 30GB CAN+US+MEX $30/month
Laptop: Lenovo Yoga 7i (16") 82UF0015US (i7-12700H, 16GB/2TB RAM/SSD, A370M GPU) Tablet: Lenovo Tab Plus (256GB)
Camera: Canon M6 Mark II | Canon Rebel T1i (500D) | Canon SX280 Music: Spotify Premium (CIRCA '08)
https://linustechtips.com/topic/1370765-help/#findComment-14972142
Pull all the cords from the back of your PC, pop the CMOS battery (looks like a watch battery) and hold the power button for 30 seconds.
I recommend just enabling XMP for most ram kits unless you're trying to set overclocking records.
My rig:
CPU: Ryzen 7 5800x
MB: Gigabyte B450 I Aorus Pro WiFi
RAM: Kingston Fury Beast RGB 32GB (2x16GB) 3600mhz CL16 (1-to-1 Infinity Fabric enabled)
GPU: Gigabyte RTX 2080 Super
*bought for $200 CAD off a friend who needed an RTX 3080, price was my reward.
CASE: InWinn A1 Plus in White with included 600w gold sfx PSU and included custom length cables
DISPLAY: 3x 20" AOC 1080p 60hz 4ms ,  32" RCA 1080p/60hz TV mounted above, all on a single arm.
Storage: C : 1TB WD Blue NVMe      D : 2TB Barracuda      E: 240GB Kingston V300 (scratch drive)
NAS: 240GB Kingston A400 + 6x 10+ year old 700GB Barracuda drives in my old FX8350+8GB DDR3 system
Logitech G15 1st Gen + Logitech G602 Wireless
Steam Controller +  Elite Series 2 controller + Logitech G29 Racing Wheel + Wingman Extreme Digital 3D Flight Stick
Sennheiser HD 4.40 Headphones + Pixel Buds 2 + Logitech Z213 2.1 Speakers
My Girlfriends Weeb-Ass Rig:
Razer Blade Pro 17 2020
10th Gen i7 10875H 8c/16t @5.1ghz
17.3" 1080p 300Hz 100% sRGB, factory calibrated, 6mm bezel
RTX 2070 Max-Q 8GB
512GB generic NVMe
16GB (2x8GB) DDR4 3200Mhz
Wireless-AX201 (802.11a/b/g/n/ac/ax), Bluetooth® 5.1, 2.5Gbit Ethernet
70.5 Whr Battery
Razer Huntsman Quartz, Razer Balistic Quartz, Razer Kraken Quartz Kitty Heaphones
*deep breath*
Razer Raptor 27" monitor, IT'S BEAUTIFUL.
https://linustechtips.com/topic/1370765-help/#findComment-14972143
1 hour ago, Dar7869 said:
I watched in yt how to cmos thingy and it says it needs jumper and how do I reset my cmos if I don't have jumper my Mobo ASRock a320
1. You have already been given a basic explanation in this thread.
2. If that wasn't sufficient, then consult your motherboard manual.
Stop messing around with the BIOS when you literally don't know the first thing about what you're doing, especially on a system you depend on for things like work or school.
In the future make a real thread title.
https://linustechtips.com/topic/1370765-help/#findComment-14972185
