My CPU is always overheating , I have a i9900kf but everytime i hit it with a  load however small like csgo, it always goes up to 100 degrees celsius. I tried almost all troubleshooting methods, for example I cleaned the pc and all the fans so dust wont be a factor . I also  have alot of fans in the system i have 240 tt liquid cooling for the cpu, 3 120mm tt fans,2 140 mm tt fans, so air flow in the pc is spot on. Also i tried to downclock the cpu with its voltage and all i get is a 1% with max temps at a staggering 99 degrees. I am curently using i9900kf and rtx 3060 with the rtx being about 30to 50 % cooler in most occasions. In idle after 15 mins my temps stay ad 50 degrees and 40 after 20 mins. After gaming temps stay as high as 80 degrees. What should i doo ? i am currently overwhelmed by this need help real bad
Thankss!
https://linustechtips.com/topic/1370689-cpu-overheating-bs/
Sounds like your pump is not moving the fluid fast enough. Does that TT AIO have fan speed control? Do you know what RPM the pump is running at? I would try speeding it up a bit.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/1370689-cpu-overheating-bs/#findComment-14971697
sounds like the cooler isn't working right, id replace it, perhaps with a higher end one from a different brand.
System Specs: AMD 5950x PBO-AutoNoctua DH-15 Black | Gigabyte x570 MasterEVGA 3080FTW3 Ultra | (2x16gb) G.Skill Royal 3600mhz CL18 | Corsair 5000D Airflow (Black) Samsung 980 Pro 2TB & Firecuda 520 1TB & Crucial MX500 2tb850W Corsair RMX | 2 Noctua A14 CPU, 6 Noctua A12x25 Intake, 3x Noctua F12 Top Exhaust, 1x Noctua A12x25 Back Exhaust
Monitors: (Main) LG Ultragear 34" 2k Ultrawide 144hz IPS '34GP83A-B' (Side) Acer Predator 27" 2k 144hz TN 'Abmiprz'
Peripherals: Corsair K100 OPX | Logitech G502 Lightspeed | Corsair Virtuoso SE | Audioengine A2+
https://linustechtips.com/topic/1370689-cpu-overheating-bs/#findComment-14975417
What rpm is the pump running at? What's the thermal paste spread look like?
What motherboard are you using? Are you using default motherboard settings? Are auto-oc settings like Multicore Enhancement disabled?
https://linustechtips.com/topic/1370689-cpu-overheating-bs/#findComment-14977569
  • 2 weeks later...
3500 rpm, thermal paste is normal its spreaded evenlt and has normal thickness not to dense, i am using a z390 plus from msi and all bios settings are normal aside from xmp , i have not enabled any overclocking
https://linustechtips.com/topic/1370689-cpu-overheating-bs/#findComment-14995639
By normal, do you mean that auto-oc settings like Multicore Enhancement are disabled? They're often enabled by default.
What case are you using and where is the rad mounted? Have you tried reseating the cpu cooling block?
https://linustechtips.com/topic/1370689-cpu-overheating-bs/#findComment-14999042
