Using single 2x8 pins PSU cable
in Graphics Cards
Is it probably fine? Yeah, though it depends on the PSU you're using (Seasonic tends to use slightly thinner cables that aren't quite as heat-resistant with higher power draws)
Â
Is it recommended? No. If you can run cables individually, do it. There are cases of people getting better overclocks by doing that, and overall it's just a better idea to run multiple cables.
kisserik93 ·
Posted in Peripherals4 -
Rick13 ·
Posted in CPUs, Motherboards, and Memory11 -
6
popularlion ·
Posted in Troubleshooting5 -
BBeard04 ·
Posted in Troubleshooting2 -
CallMe_David ·
FancyPants101 ·
Posted in Troubleshooting1
play_circle_filled
Latest From The WAN Show:
