Help me with partition management (more info in the post)
Solved by Electronics Wizardy,
Id just fully remove that second D drive and make one big partition.
You should be able to remove the recovery partition, but have a backup first.
Gparted can move the partition if needed, use it in a linux live disk.
Featured Topics
Max853lolz ·
Posted in Linux, macOS and Everything Not-Windows0 -
cattaru ·
Posted in Peripherals0 -
Emil_Loenneberg SE ·
Posted in Operating Systems1 -
Samueldcoker ·
Posted in Troubleshooting0 -
2
Imrestarted ·
Posted in New Builds and Planning2 -
MartinATL ·
play_circle_filled
Latest From ShortCircuit:
Feels like I'm wearing nothing at all... - Shokz OpenFit Air
