Budget (including currency): 1500
Country: United States
Games, programs or workloads that it will be used for: Cod:Warzone, Overwatch, Forza
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): It’s gonna be my first PC and I’m gonna get a 1440 144Hz monitor but I don’t know which one, so I’d also like help with that. Budget for the monitor is an additional 450 dollars. Here’s a link to what I’ve picked on PC part picker:https://pcpartpicker.com/list/R9wQmk
https://linustechtips.com/topic/1368965-building-a-pc/
Get a 5800X, 3600 Cl16 RAM, and you should be good, though a 3070 would be better for this system.
https://linustechtips.com/topic/1368965-building-a-pc/#findComment-14959341
Here's a few changes
PCPartPicker Part List: https://pcpartpicker.com/list/LhYGp2
CPU: AMD Ryzen 5 5600X 3.7 GHz 6-Core Processor  ($272.99 @ Amazon)
CPU Cooler: ARCTIC Liquid Freezer II 240 56.3 CFM Liquid CPU Cooler  ($85.99 @ Newegg)
Motherboard: MSI MPG B550 GAMING EDGE WIFI ATX AM4 Motherboard  ($196.99 @ Newegg)
Memory: Corsair Vengeance RGB Pro 16 GB (2 x 8 GB) DDR4-3600 CL18 Memory  ($89.99 @ Newegg)
Storage: Western Digital Blue SN550 1 TB M.2-2280 NVME Solid State Drive  ($99.00 @ Amazon)
Video Card: NVIDIA GeForce RTX 3060 Ti 8 GB Founders Edition Video Card
Case: Corsair iCUE 220T RGB Airflow ATX Mid Tower Case  ($99.99 @ Amazon)
Power Supply: Corsair RM (2019) 750 W 80+ Gold Certified Fully Modular ATX Power Supply  ($114.99 @ Newegg)
Operating System: Microsoft Windows 10 Home OEM 64-bit  ($108.78 @ Other World Computing)
Total: $1068.72
Generated by PCPartPicker 2021-08-29 01:24 EDT-0400
https://linustechtips.com/topic/1368965-building-a-pc/#findComment-14959342
would get a r5 5600xt instead of the 3700.
no need for the aio unless you really care about looks- its not going to make your pc much better.
you can use sdkeys for cheap windows 10.
|:Insert something funny:|
https://linustechtips.com/topic/1368965-building-a-pc/#findComment-14959346
Total: $1068.72
Thanks for the help
https://linustechtips.com/topic/1368965-building-a-pc/#findComment-14959350
CPU: AMD Ryzen 5 5600G 3.9 GHz 6-Core Processor  ($255.00 @ Amazon) 5600X if you can find a dGPU.
CPU Cooler: ARCTIC Liquid Freezer II 360 RGB 48.8 CFM Liquid CPU Cooler  ($140.21 @ Amazon)
Motherboard: Asus ROG STRIX B550-F GAMING ATX AM4 Motherboard  ($143.30 @ Amazon)
Memory: Patriot Viper Steel 16 GB (2 x 8 GB) DDR4-3733 CL17 Memory  ($79.98 @ Amazon)
Storage: Western Digital SN750 500 GB M.2-2280 NVME Solid State Drive  ($59.99 @ Western Digital)
Power Supply: MSI MPG A-GF 750 W 80+ Gold Certified Fully Modular ATX Power Supply  ($87.50 @ Amazon)
Total: $865.97
Generated by PCPartPicker 2021-08-29 03:20 EDT-0400
https://linustechtips.com/topic/1368965-building-a-pc/#findComment-14959464
