Help with radiator
Solved by WunderWuffle,
For that setup, I would recommend 4x 120mm of radiator space. Also, there isn't much benefit to watercooling to motherboard if you're not going to be using ln2 or pushing a butt ton of voltage through it.
derekchan ·
Posted in New Builds and Planning4 -
5
1
5
kerriya ·
Posted in Cases and Mods9 -
octester ·
Posted in Troubleshooting7 -
DavidPatrascu ·
Posted in General Discussion9
play_circle_filled
Latest From ShortCircuit:
