Build for a friend
Go to solution Solved by Real_PhillBert,
Also he'll no to windows 8.1 he already has an 8.1 laptop and he hates it. I don't want to insert an SSD yet. He doesn't play games that need that, he is really making 5his build to have it look nice. He mostly plays GM. Also Asus Cards are just not my thing or his. He liked the MSI and I have one myself so I am confident with that. I just was making sure that case was OK but I guess I need a different case... darn
I think I changed everything to suit your preferences.
PCPartPicker part list: http://pcpartpicker.com/p/3nKed
Price breakdown by merchant: http://pcpartpicker.com/p/3nKed/by_merchant/
CPU: Intel Core i5-4670K 3.4GHz Quad-Core Processor  ($189.99 @ Amazon)
Motherboard: MSI Z87-G45 Gaming ATX LGA1150 Motherboard  ($139.99 @ Micro Center)
Memory: Kingston Black 8GB (2 x 4GB) DDR3-1600 Memory  ($64.99 @ Amazon)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($57.98 @ OutletPC)
Video Card: MSI GeForce GTX 770 2GB Video Card  ($329.99 @ Amazon)
Case: Fractal Design Define R4 w/Window (Black Pearl) ATX Mid Tower Case  ($119.99 @ NCIX US)
Power Supply: SeaSonic G 550W 80+ Gold Certified Semi-Modular ATX Power Supply  ($82.99 @ Mwave)
Operating System: Microsoft Windows 7 Home Premium SP1 (OEM) (64-bit)  ($89.98 @ OutletPC)
Total: $1075.90
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2014-04-07 16:27 EDT-0400)
I used the Define R4 because I think it looks great, another excellent option to look at is the NZXT H440. The NZXT also has a great reputation around here.
I do wonder why you do not wish to integrate an SSD? They will increase performance a fair bit and fit into your budget.
CPU Intel i5 4670K
MOBO OC MSI Z87-G45 Gaming
RAM Corsair DDR3 2X4 1600MHz
GPU MSI GeForce GTX 770 OC Twin Frozr IV 2GB
HDD Seagate Barracuda 3.5 1TB
PSU BeQuiet! Purepower L7 630Watt 80+Bronze
Case Corsair Obsidian 350D
OS Windows 7 Home Premium
I ahve 4000 Polish ZŁ for this PC so a 1200 dollar PC since the pirces in Poland are higher
He will add an h100i later.
https://linustechtips.com/topic/136786-build-for-a-friend/
Its a good idea to get an aftermarket CPU cooler. What is your main use? Gaming?
Edit: *Derp* I skipped right over your bit about a H100i. My bad.
https://linustechtips.com/topic/136786-build-for-a-friend/#findComment-1817610
Hez guzy I would add an SSD but since we are in Poland this is the max. Main use for the guz is gaming. He doesnt know a ton about computers but he wants a good gaming PC that will run games well. Do zou see any mistakes
First: Welcome to the Forum!
Second: The MSI Z87-G45 is an ATX board, and will not fit in to the 350D as it is mATX.
https://linustechtips.com/topic/136786-build-for-a-friend/#findComment-1817709
PCPartPicker part list: http://pcpartpicker.com/p/3nH3z
Price breakdown by merchant: http://pcpartpicker.com/p/3nH3z/by_merchant/
Memory: Kingston Black 8GB (2 x 4GB) DDR3-1600 Memory  ($64.99 @ Newegg)
Storage: Kingston SSDNow V300 Series 120GB 2.5" Solid State Disk  ($67.99 @ Micro Center)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($54.98 @ OutletPC)
Video Card: Asus GeForce GTX 770 2GB Video Card  ($329.99 @ Micro Center)
Case: Corsair 450D ATX Mid Tower Case  ($119.99 @ Amazon)
Power Supply: Corsair CSM 550W 80+ Gold Certified Semi-Modular ATX Power Supply  ($69.99 @ Newegg)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit)  ($89.98 @ OutletPC)
Total: $1127.89
(Generated by PCPartPicker 2014-04-07 14:59 EDT-0400)
I assumed your currency exchange was accurate, so I kept it under $1200
https://linustechtips.com/topic/136786-build-for-a-friend/#findComment-1817723
https://linustechtips.com/topic/136786-build-for-a-friend/#findComment-1817955
Total: $1075.90
https://linustechtips.com/topic/136786-build-for-a-friend/#findComment-1818068
Total: $1075.90
PC PartPicker gives weird prices and I t doesn't well reflect the parts. I was making sure with the case. THe guy decided to go with the Corsair C70 over the R4. NZXT ia again hard to find in Poland, I was looking fior it but failed to find it. I am not going with an SSD since we can add it later anyway and the games he play are Garry's Mod and games like that. He dfoesn't need that much more speed. I talked it over with him bu he doesn't plan on playing other games. I did ask him what the poibnt of a 4000Zł PC is he just told me he wanted a better PC than mine :P
https://linustechtips.com/topic/136786-build-for-a-friend/#findComment-1822694
