Fan control problems
Solved by dragosudeki,
I have no clue... But I can't replace my AF140's I just got them !
I don't know if they're faulty or what but I can hear them humming away on my desk when I sit down
They are pretty loud fans and with the radiator it will get louder. You can try the fan controller, but I don't know if it will make a difference. Also, I think some fans actually make noise when its at low voltage, though it might not be the AF140s.
