Headset USB Port Matter?
ChaoticChaosx
So I have an ASUS TUF x570 and recently ran out of USB ports for my devices. 6 Ports in total.
3 peripherals
1 Mic
1 Soundbar
1 Headset Stand
1 Headset USB Dongle
Now my headset stand has USB ports in it. My 3 peripherals are razer products synced together with my corsair fans and RAM. So I'd rather not put one of these in my headset stand for a chance to them become not synced correctly.
Can I take my headset USB dongle out my motherboard and use it from my headset stand?
If I can will this change the audio quality even with the EQ settings I have set?
or can I put my mic in it can and it not change it sound quality either?
First watercooled System
Build Name: Frost
OS: Windows 11 Pro 64-bit
Monitor: Alienware AW3423DWF 1800R Curved Ultrawide 3440x1440 QD-OLED 157hz 10 bit 0.1ms
Chassis: Lian Li 011 Dynamic EVO w/ 2x120mm Corsair QL RGB Fans on the bottom 1x120mm on back exhaust
Top Rad & Fans:  Corsair 54mm 360mm w/ 3x120mm Corsair ML Pro RGB Fans
Side Rad & Fans: Corsair 30mm 360mm w/ 3x120mm Corsair QL RGB Fans
Motherboard: Asrock X670E Steel Legend
CPU: AMD Ryzen 7 7800X3D w/ Corsair XC7 RGB Pro w/ Kyrosheet
Memory/RAM: Corsair Dominator RGB DDR5 2x16GB 32GB 6000Mhz
GPU: Asus GeForce RTX 4080 TUF w/ EK-Quantum Vector2 Nickel/Plexi & Backplate
Pump/Reservoir: Corsair XD5 RGB
Coolant: EK Mystic Fog
PSU: EVGA Supernova 1000w G3 w/ custom modmesh black & white cables from cablemod
Boot/OS SSD: Samsung 970 EVO Plus 500GB NVMe
WZ/2042 SSD: Samsung 850 EVO 250GB
Game SSD: Samsung 980 Pro 1TB
Performance/Editing HDD: Western Digital Black 1TB
Storage HDD: Western Digital Blue 1TB
Mouse: Razer Lancehead Tournament Edition/Razer Mamba
Mouse Mat: Corsair MM700 RGB
Keyboard: Razer Ornata Chroma
Microphone: HyperX Quadcast
Headset: Razer Blackshark v2 Pro
Eyewear/Glasses: Gunnar Optiks Razer FPS
Camera: Razer Kiyo Pro
I did, FOR SCIENCE!
Results are in: I hear no difference since digital signal is digital signal. So as I only tested with Warzone anyway.
Build Name: Frost
