It should be fairly easy to do. I believe you just have to remove the screws holding in the fortifier (backplate), and the armor will come off.
Also, i see that you are new here so welcome to the forums! :)
#LinusKitchenTips /// "Better than useless" - Linus Sebastian
LTT Holy bible: Code Of Conduct
Project Toaster [My Silver NCASE M1 V2 Build-log]
Main Rig
 Case: Fractal Design Define R5 CPU: INTEL
i5 3570k Cooler: CM Hyper 212 Evo Mobo: Maximus V Gene Z77 GPU: Gigabyte GTX 970 G1 Gaming (w/ 0% fan mode) RAM: Corsair Dominator Platinum 2x8GB 1600mHz Storage: OCZ VERTEX 4 256GB PSU: Corsair AX860 Monitor: ASUS PB278Q 1440p 27" Headphones: QPAD QH-90 Laptop
Macbook Pro Retina 13" i5 256Gb Early 2015
Phone
Oneplus One 64GB Sandstone Black
hi guys i need help on how to remove the thermal armor on the z87 sabertooth mobo i want to paint it white when i get it and was wondering if anyone has a tutorial on how to remove it or could give me some info on how to remove it thanks.
There should be screws around the board that keeps the armor in place.
Remove the small screw on the back of the motherboard, you could have answered this question easily by looking through your manual instead of making a thread about it.
-The Bellerophon- Obsidian 550D-i5-3570k@4.5Ghz -Asus Sabertooth Z77-16GB Corsair Dominator Platinum 1866Mhz-x2 EVGA GTX 760 Dual FTW 4GB-Creative Sound Blaster XF-i Titanium-OCZ Vertex Plus 120GB-Seagate Barracuda 2TB- https://linustechtips.com/main/topic/60154-the-not-really-a-build-log-build-log/ Twofold http://linustechtips.com/main/topic/121043-twofold-a-dual-itx-system/ How great is EVGA? http://linustechtips.com/main/topic/110662-evga-how-great-are-they/#entry1478299
yes he could have, but then this is the internet. you expected someone NOT to be lazy? haha
Anyway, @OP, what paint will you be using?
i dont have the board yet im currently saving for it so i tohought i would ask ahead of time in order to prep everything
also i don't know yet i was thinking along the lines of using maybe some plastic model spray paint or plasty dipping it in white then outlining the words in black model paint i'm certainly open to suggestions on what will work best.
also i see what you mean now i can see the screw holes for the backplate thanks
