Budget (including currency): keep under $500 us dollars still don't max
Country: USA
Games, programs or workloads that it will be used for: steam games
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): i have a intel i5 2.9 ghz for CPU. i have a GTX 1650 super GPU. big case i don't know my motherboard type but i do know the CPU socket is a LGA1151 here is my computer name
Legion T5-28IMB05 Desktop (Lenovo) - Type 90NC
i want to get a mother board and a CPU but i have never done a computer before so i have no clue where to start also the motherboard need to fit the 1650 super
if you think it might be better to upgrade something other than the CPU and motherboard please say :)
and if i am missing something please say as well
https://linustechtips.com/topic/1366009-new-computer-parts/
Can you list the exact cpu you have?
Why are you upgrading?
https://linustechtips.com/topic/1366009-new-computer-parts/#findComment-14937763
31 minutes ago, CostinNathan said:
my power supply is 500w but my uncle is giving me a 1000w so im good on that also. my cpu is a  Intel(R) Core(TM) i5-10400F CPU @ 2.90GHz, 2904 Mhz, 6 Core(s), 12 Logical Processor(s)
High wattage doesn't mean it's of good quality, keep that in mind when you go to use it in the future.
https://linustechtips.com/topic/1366009-new-computer-parts/#findComment-14937849
Budget (including currency):    keep under $500 US don't try to max though
Country:  Washington
Games, programs or workloads that it will be used for: my games take a long time to load and are laggy on normal settings
Processor    Intel(R) Core(TM) i5-10400F CPU @ 2.90GHz, 2904 Mhz, 6 Core(s), 12 Logical Processor(s)
BIOS Version/Date    LENOVO O4NKT17A, 10/26/2020
BaseBoard Version    SDK0J40709 WIN 3259722694967
Installed Physical Memory (RAM)    16.0 GB    DDR4
1000w power
big case
please say what to do next and what to think about
https://linustechtips.com/topic/1366009-new-computer-parts/#findComment-14937884
I merged your threads to avoid double posting.
Just make sure to quote when you respond and I'll know when you do.
So your system is fairly competent as is, I don't really think you need much of an upgrade.
Slowness may come from a hard drive if you don't have your operating system or games on an SSD.
https://linustechtips.com/topic/1366009-new-computer-parts/#findComment-14937891
