Well basically all I have in my computer room is desks and one chair, it echos like a Bitch so I nailed pillows abd blankets to the wall, plus the insulation between apartments here is horrid so I'd like to sound proof so I can be somewhat loud(not playing drums or anything) and also have no echo in my room anyone got suggestions for some sound proofing crap like those foam wedge panels or anything I just have no idea what's good so I want good for cheap lol also I wad told I should get those foam wedge things and some bass catches or something... So basically I just need some suggestions on what to get
https://linustechtips.com/topic/136596-sound-proofing/
I had the same problem when I was in a house with stone floors and bares walls. So I bought some of these: http://www.moddiy.com/products/Premium-Pyramid-Noise-Dampening-Foam-(50x50cm).html?gclid=CPe39rLOzb0CFc1afgod5gIAZQ
it's godly, I got 10 of them to place around my room and my room became 20x quieter
https://linustechtips.com/topic/136596-sound-proofing/#findComment-1815185
looking for some a bit cheaper though and also are bass traps useful
https://linustechtips.com/topic/136596-sound-proofing/#findComment-1815203
You could honestly like what @LancerBG said, use milk cartons. You can buy stacks of them cheaply, and you can even paint them so it doesn't look terrible.
ik it works but I'm not that ghetto cheap lol especially when people come over that would be like Wtf egg cartons
https://linustechtips.com/topic/136596-sound-proofing/#findComment-1815212
It sounds like egg cartons would be the best option.
Mice never had to soundproof anything but from what others are saying they work and don't cost much.
Someone told Luke and Linus at CES 2017 to "Unban the legend known as Jerakl" and that's about all I've got going for me. (It didn't work)
https://linustechtips.com/topic/136596-sound-proofing/#findComment-1815217
