Power consumption
5 minutes ago, Curioisman said:but the manufacturer recommends a 300w psu minimum for the card, why is that so, My own personal cpu (i5-9400f) has a TDP of 65, idk if it uses 65w or 75w, but adding all those up, 75w+75(?)w = 150 and adding to that like the other extra stuff, ram storage keyboard etc. adding like +30, so it would be 180w, why wouldn't some1 want a 200w psu or 250w. I am just thinking.
The graphics card manufacturer doesn't know the rest of your system specifications. While you have an i5 9400f CPU that only draws 65W someone else might be using the same GTX 1650 in a system with an i9 11900k which can draw 150W+ which would increase the overall system power consumption.
Take the power supply recommendations provided by the graphics card manufacturer with a grain of salt, they're basically meaningless as you can't determine the power requirements of an entire system based on only one part.
