I have an asus laptop i7-8750HQ and 1050ti. I play Valorant  720p at all low and still not hitting 120fps. When I launch game, CPU runs at around 3.6Ghz but after some time it drops to 2.2Ghz(base clock) . I use Ultimate performance battery mode and fans are set to max. I disable my antivirus while gaming and Nvidia control panel settings are also optimised. CPU temps are 80-90 and gpu is in 80s. There is no thermal throttling I checked using HWInfo.
https://linustechtips.com/topic/1365055-cpu-clock-speed-drops-to-base-clock/
Except what youre describing is totally thermal throttling …
(also for hwi its not thermal throttling  as long its not under base clock, fyi)
-Scott Manley, 2021
-Scott Manley, 2021
