Using EVGA gpu cable on a fps power supply
Solved by Spotty,
1 hour ago, Alite said:I did the measurements directly to the PSUs GPU pins(without vga cables) jump started both units and they gave the same 12v on the bottom right 3 pins (with the connector hole/ clip on top).
Measure at the end of the cables as well. The cables might twist on one and reverse it on the end that plugs in to the GPU.
It is made by FSP, but that doesn't necessarily mean the cables are the same.
