My first build Need help
Go to solution Solved by Herman Mcpootis,
8 hours ago, Banana81420 said:
My budget is 1700.00
which country are you in?
17 minutes ago, Banana81420 said:
don’t know if my parts I’m good
What is your budget, if you have one?
Also,
Do not pay $283 for a Ryzen 5 3600
Do not pay $270 for a GTX 1050 Ti
PSU is more than you need (unless you are upgrading stuff in the future)
Gaming With a 4:3 CRT
System specs below
CPU: AMD Ryzen 7 5700X with a Noctua NH-U9S cooler
Motherboard: Gigabyte B450 Aorus M (Because it was cheap)
RAM: 32GB (4 x 8GB) Corsair Vengance LPX 3200Mhz CL16
GPU: EVGA GTX 980 Ti SC Blower Card
HDD: 7200RPM TOSHIBA DT01ACA100 1TB, External HDD: 5400RPM 2TB WD My Passport
SSD: 1tb Samsung 970 evo m.2 nvme
PSU: Corsair CX650M
Displays: ViewSonic VA2012WB LCD 1680x1050p @ 75Hz
Gateway VX920 CRT: 1600x1200@75Hz, 1200x900@100Hz, 960x720@125Hz, 800x600@140Hz
Gateway VX900 CRT: 1600x1200@75Hz, 1200x900@100Hz, 960x720@120Hz (Can be pushed to 175Hz)
Keyboard: Thermaltake eSPORTS MEKA PRO with Cherry MX Red switches
Good size budget, just don't over pay for stuff.
The R5 3600, $200 max.
The GTX 1050 Ti... don't bother buying new right now.
System specs below
PSU: Corsair CX650M
7 hours ago, Banana81420 said:
 My first build
Garbage overpriced aio
Garbage overpriced rgb ram
Garbage case with no airflow
Downgrading the cpu abd gpu to accomodate those garbage overpriced uneccesary parts
7/10
Ive seen worse but this isnt really that bad
Like atleast the psu is decent
https://pcpartpicker.com/list/WGsFj2
Easily obliterates your list
5800x 8 core, great for gaming and if games start using 8 cores or you wanna use some productivity programs then this cpu has got you covered
Cheap but decent cooler as i bet you arent gonna do any overclocking anyways
B550 tomahawk, decent b550 board with quite alot of features but if you dont need them consider a b550m bazooka
Cheaper nvme that still has dram cache, you dont need a faster ssd cause the speed isnt noticable in load times, only noticable in moving massive files like 4k video
Good airflow rgb case that has quite alot of rgb fans
Gpu is up to you
If you are going for an rgb ram but clean case look then maybe go for this
https://pcpartpicker.com/list/nHVQkX
Chose the ram that you like most out of these 2
White pure base 500 case
Gpu is up to you
Thank
you
