Need Help finding water cooler components for MSI Ventus XC1660 OC on a budget!!
Solved by RONOTHAN##,
Most people one this forum would agree that water cooling a lower end GPU is almost never worth it. Even if you save money buying barb fittings, you'll spend $30 on fittings, $30 on a radiator, and most GPU blocks are $100+, or if you get a CPU block and jury rig it on, you''ll spend closer to $50, and you'll spend $50 on a pump and reservoir if you cheap out on it. Together you'll spend somewhere around $150-200, and for that price you could sell the card on eBay and buy a GTX 1080 or if you're lucky a 1080 Ti. There would be no way to overclock the difference with water cooling.
If you're dead set on doing it, the only way it would make sense is if you can get a good deal on used water cooling equipment.
