Water Cooling
Solved by Biohazard777,
47 minutes ago, xXDuckzXx said:I Would like to get into the world of water cooling I don't know exactly what's good or bad cause I'm looking for something not stupidly expensive, Unless the compromise means I might loose my PC
50 to 85 USD聽
Thanks for the help any tips would be nice to!
聽聽
TL;DR cheap / small liquid coolers are a bad deal. 120mm radiator ones are usually never a good deal, so you should be looking at 240mm at least, and those are typically near or over your upper budget limit. (85$ - 120$)
