I've been told that I should buy a full copper cat5e ethernet cable instead of a stranded one for using my 50/50 fiber internet.
This is the only one I could find that isn't a poor quality cable and mentions that it is full copper, should it work fine?
https://m.takealot.com/hi-speed-20m-cat6-cable/PLID70625576
Edit : I think I'll buy this one instead
https://m.takealot.com/baobab-cat5e-networking-patch-cable-20m/PLID52348594
https://linustechtips.com/topic/1360554-ethernet-cable/
Over what range? Whats your cat rating on your stranded cable (it should be printed on text of the cable)?
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
https://linustechtips.com/topic/1360554-ethernet-cable/#findComment-14899972
Stranded/solid, doesn't really matter for most home applications.
I'd go with whatever the manual for the fiber router (where the fiber run plugs into) gives you, or what the ISP said. Stranded cabling can take more abuse than solid, but it depends on the application.  All but the crappiest 5e cable can handle gigabit.  5E UTP ethernet cabling.  Been used for years.  What you have will work too, but if it's solid, you don't get as much flexibility.
https://www.flukenetworks.com/blog/cabling-chronicles/101-series-stranded-vs-solid-patch-cords
Now if what's coming out of that box is something other than standard gigabit, might be something else you need.
https://linustechtips.com/topic/1360554-ethernet-cable/#findComment-14899973
Unless you want the signal to go to a nearby village literally any cable will do 50/50 with no issues.
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/1360554-ethernet-cable/#findComment-14899982
what about patch cable? Since I now know that stranded/solid doesn't matter I think I'll go with the one with best reviews which is this one.It says patch though and I am unsure if I can use this.
https://linustechtips.com/topic/1360554-ethernet-cable/#findComment-14900015
What range? I don't know what that means,my speed? 50mbs/upload and 50mbs download. Right now I am using an LTE router with a cat5e cable.
https://linustechtips.com/topic/1360554-ethernet-cable/#findComment-14900023
Just now, WestTexan said:
What range?
As in the cable length. If you gonna go wireless, honestly stranded or solid is gonna be fine in durability and speed. Keep using what you got if its already 5e.
https://linustechtips.com/topic/1360554-ethernet-cable/#findComment-14900028
Well,the cable I need must be 20 meters because the router will be in the kitchen.Right now I'm using a 1 meter cat5e cable since the router is next to my desktop PC
https://linustechtips.com/topic/1360554-ethernet-cable/#findComment-14900032
Stranded vs Solid isn't the issue. You want to stay away from Copper Clad Aluminum cabling, but even at that distance it should be fine. Just beware that your Microwave will likely effect your WiFi performance as 2.4 Ghz is also used by the Magnetron in your Microwave, the only difference is your Microwave will output shitloads more power than the router.
https://linustechtips.com/topic/1360554-ethernet-cable/#findComment-14900046
Also consider humidity and grease, a kitchen might not be the best place to have it unless its very well ventilated.
https://linustechtips.com/topic/1360554-ethernet-cable/#findComment-14901202
