No USB power after shutdown, pls help
Solved by Hygel,
The board most likely just doesn't support it. HP (along with most other OEMs) are known for skimping out on boards and other parts that they think people won't notice, which leaves you with a surprising lack of features. I looked into the board for a few minutes and it looks like a pretty barebones one that they just picked out because it was cheap, so it likely doesn't have some of the features that you may consider standard. You can try contacting support to ask them if there's some secret way of doing it that is nowhere to be found on the internet but they're also known for abysmal customer service so that may not take you anywhere.
