Thoughts/Review on first PC
By
Aetix
in New Builds and Planning
Solved by danalog,
Welcome to LTT!
Seems like a quite decent build that will be usable for a while. As 1st comment said, you did overpay a lil bit for your GPU but nothing major. The only thing I would recommend is adding a 2 or 4tb hdd in addition to the SSD, because you may find in the future that 500gb isn't enough.
popularlion ·
Posted in Troubleshooting1 -
CallMe_David ·
FancyPants101 ·
BoBo6107 ·
R_public ·
Posted in Networking14 -
apoyusiken ·
Posted in PC Gaming1 -
6
