Network HELL! P2P Connection on 10gbe fast one way not the other.
Bmoney
Asus Rampage VI Extreme and Asus Zenith Exetreme Alpha
Ubuntu 20 and Windows 10
P2P Cat6A direct connection. Jumbo Packets and MTU 9000
Crappy Speeds Why
Ethtool read out
Settings for enp9s0:
        Supported ports: [ TP ]
        Supported link modes:   100baseT/Full
                                1000baseT/Full
                                10000baseT/Full
                                2500baseT/Full
                                5000baseT/Full
        Supported pause frame use: Symmetric
        Supports auto-negotiation: Yes
        Supported FEC modes: Not reported
        Advertised link modes:  100baseT/Full
                                1000baseT/Full
                                10000baseT/Full
                                2500baseT/Full
                                5000baseT/Full
        Advertised pause frame use: Symmetric
        Advertised auto-negotiation: Yes
        Advertised FEC modes: Not reported
        Speed: 10000Mb/s
        Duplex: Full
        Port: Twisted Pair
        PHYAD: 0
        Transceiver: internal
        Auto-negotiation: on
        MDI-X: Unknown
        Supports Wake-on: g
        Wake-on: d
        Link detected: yes
Iperf 3 result Server First then Client
Accepted connection from 10.2.2.3, port 54847
[  5] local 10.2.2.1 port 5201 connected to 10.2.2.3 port 54848
[ ID] Interval           Transfer     Bitrate
[  5]   0.00-1.00   sec   443 MBytes  3.72 Gbits/sec
[  5]   1.00-2.00   sec  80.6 MBytes   676 Mbits/sec
[  5]   2.00-3.00   sec  0.00 Bytes  0.00 bits/sec
[  5]   3.00-4.00   sec  0.00 Bytes  0.00 bits/sec
[  5]   4.00-5.00   sec  0.00 Bytes  0.00 bits/sec
[  5]   5.00-6.00   sec  0.00 Bytes  0.00 bits/sec
[  5]   6.00-7.00   sec  0.00 Bytes  0.00 bits/sec
[  5]   7.00-8.00   sec  0.00 Bytes  0.00 bits/sec
[  5]   8.00-9.00   sec  0.00 Bytes  0.00 bits/sec
[  5]   9.00-10.00  sec  0.00 Bytes  0.00 bits/sec
[  5]   0.00-10.06  sec   524 MBytes   437 Mbits/sec                  receiver
Server listening on 5201
Client commad
Connecting to host 10.2.2.3, port 5201
[  5] local 10.2.2.1 port 39938 connected to 10.2.2.3 port 5201
[ ID] Interval           Transfer     Bitrate         Retr  Cwnd
[  5]   0.00-1.00   sec   995 MBytes  8.34 Gbits/sec    0    228 KBytes
[  5]   1.00-2.00   sec  1.01 GBytes  8.66 Gbits/sec    0    228 KBytes
[  5]   2.00-3.00   sec  1.00 GBytes  8.60 Gbits/sec    0    228 KBytes
[  5]   3.00-4.00   sec  1017 MBytes  8.53 Gbits/sec    0    228 KBytes
[  5]   4.00-5.00   sec  1.01 GBytes  8.68 Gbits/sec    0    228 KBytes
[  5]   5.00-6.00   sec  1012 MBytes  8.48 Gbits/sec    0    228 KBytes
[  5]   6.00-7.00   sec   990 MBytes  8.31 Gbits/sec    0    228 KBytes
[  5]   7.00-8.00   sec  1013 MBytes  8.50 Gbits/sec    0    228 KBytes
[  5]   8.00-9.00   sec  1013 MBytes  8.50 Gbits/sec    0    228 KBytes
[  5]   9.00-10.00  sec  1004 MBytes  8.42 Gbits/sec    1    228 KBytes
[  5]   0.00-10.00  sec  9.90 GBytes  8.50 Gbits/sec    1             sender
[  5]   0.00-10.00  sec  9.90 GBytes  8.50 Gbits/sec                  receiver
What the Hell is wrong.
Are you sure the ISP plan is symetrical 10 gigabit? Many ISP plans only advertises its fastest speed and then have a different speed from one way or the other (usually faster speed on the download), so that could be your issue.
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
I am human. I'm scared of the dark, and I get toothaches. My name is Frill. Don't pretend not to see me. I was born from the two of you.
Not ISP this is a P2P LAN connection directly attached.
Crappy Speeds Why
Ethtool read out
                                1000baseT/Full
                                10000baseT/Full
                                2500baseT/Full
                                5000baseT/Full
                                1000baseT/Full
                                10000baseT/Full
                                2500baseT/Full
                                5000baseT/Full
        Speed: 10000Mb/s
        Duplex: Full
        Port: Twisted Pair
        PHYAD: 0
        MDI-X: Unknown
        Supports Wake-on: g
        Wake-on: d
        Link detected: yes
Client commad
That's pretty much what I see tbh.  Both upgraded PCs and a refresh install of Windows 10 onto a brand new PC had similar results.
Connecting to host god.lan, port 5201
[  5] local 192.168.1.253 port 35186 connected to 192.168.1.1 port 5201
[  5]   0.00-1.00   sec   982 MBytes  8.24 Gbits/sec    0    471 KBytes
[  5]   1.00-2.00   sec  1024 MBytes  8.59 Gbits/sec    0    448 KBytes
[  5]   2.00-3.00   sec  1.00 GBytes  8.62 Gbits/sec    0    425 KBytes
[  5]   3.00-4.00   sec  1020 MBytes  8.56 Gbits/sec    0    456 KBytes
[  5]   4.00-5.00   sec  1009 MBytes  8.46 Gbits/sec    0    422 KBytes
[  5]   5.00-6.00   sec  1000 MBytes  8.39 Gbits/sec    0    462 KBytes
[  5]   6.00-7.00   sec  1004 MBytes  8.42 Gbits/sec    0    439 KBytes
[  5]   7.00-8.00   sec  1020 MBytes  8.56 Gbits/sec    0    422 KBytes
[  5]   8.00-9.00   sec  1022 MBytes  8.57 Gbits/sec    0    422 KBytes
[  5]   9.00-10.00  sec  1009 MBytes  8.46 Gbits/sec    0    436 KBytes
[  5]   0.00-10.00  sec  9.88 GBytes  8.49 Gbits/sec    0             sender
[  5]   0.00-10.00  sec  9.88 GBytes  8.48 Gbits/sec                  receiver
iperf Done.
[root@server prosody]# iperf3 -Rc god.lan
Reverse mode, remote host god.lan is sending
[  5] local 192.168.1.253 port 35190 connected to 192.168.1.1 port 5201
[  5]   0.00-1.00   sec   587 MBytes  4.92 Gbits/sec
[  5]   1.00-2.00   sec   287 MBytes  2.41 Gbits/sec
[  5]   2.00-3.00   sec   373 MBytes  3.13 Gbits/sec
[  5]   3.00-4.00   sec   468 MBytes  3.92 Gbits/sec
[  5]   4.00-5.00   sec   365 MBytes  3.06 Gbits/sec
[  5]   5.00-6.00   sec   392 MBytes  3.28 Gbits/sec
[  5]   6.00-7.00   sec   421 MBytes  3.53 Gbits/sec
[  5]   7.00-8.00   sec   311 MBytes  2.61 Gbits/sec
[  5]   8.00-9.00   sec   406 MBytes  3.41 Gbits/sec
[  5]   9.00-10.00  sec   304 MBytes  2.55 Gbits/sec
[  5]   0.00-10.00  sec  3.82 GBytes  3.28 Gbits/sec                  sender
[  5]   0.00-10.00  sec  3.82 GBytes  3.28 Gbits/sec                  receiver
I've tweaked everything I can think of, its some sort of bug in Windows 10 since an update around September 2020 I think as if you Google Windows upstream speed issues there are other people complaining.
I only managed to get it THAT fast by disabling interrupt moderation on the network cards and I found jumbo frames causes more harm than good in the long run as it caused delays when accessing the Internet. (but mine isn't point to point, its into a switch so you're probably fine there)
Router:  Intel N100 (pfSense) WiFi6: Zyxel NWA210AX (1.7Gbit peak at 160Mhz)
WiFi5: Ubiquiti NanoHD OpenWRT (~500Mbit at 80Mhz) Switches: Netgear MS510TXUP, MS510TXPP, GS110EMX
ISPs: Zen Full Fibre 900 (~930Mbit down, 115Mbit up) + Three 5G (~800Mbit down, 115Mbit up)
iperf Done.
Ok yeah I did iperf on my server and got 28GB/s back to itself
Then I did it with the windows machine only 6GB/s.
I think I narrowed like you said to the Windows. Get lame speed on my 1GB port too with transfers at 80MB/s and bumpy.
I disable all offloads and bupkis.
My Laptop with a USB-3 NIC works great oddly.
iperf Done.
Definitely a local windows problem.
My Laptop and USB NIC is fine. Thinking about reinstall but don't know if it will work.
It didn't for me, I had it on a fresh install on a brand new Ryzen 5950X, its baffling.  Boot Linux on the same hardware, no problems at all.
I have two laptops, two desktops, they all have the same problem.  Even on WiFi the upstream seems to be limited compared to the downstream more than it used to be.  Same on Windows 11 even which I had kinda hoped it was a known issue they might have fixed. 😞
I wanna try Windows Pro for Workstation as it has more unlocked hardware features.
Also worth noting, when I said I turned of interrupt moderation, I did so on the Linux box too.  Just turning it off on Windows wasn't enough, turning it off on my NAS is what allowed me to get decent downstream speeds to the Windows machine at the cost of higher CPU usage on my NAS.
