Budget (including currency): £1200
Country: UK
Games, programs or workloads that it will be used for: gaming and some Game Development
Current parts list: https://uk.pcpartpicker.com/list/D7sJK3
Edited by St0nl0y
Added peripherals to parts list
https://linustechtips.com/topic/1358937-first-mini-itx-pc-recommendations/
The case is more of what I like to call "baby ATX," it is a lot like a micro ATX tower. It isn't terribly small.
If you want a much smaller case, look for the Silverstone Sugo SG13. It comes in a few colors, nice ventilated front panel, and lots of room inside to work with. I recommend one 120 millimeter fan as intake
Primary PC:
PSU tier list
How many watts do I need?
https://uk.pcpartpicker.com/list/KdrHcT
Tried to go of the case recommendation and made an AMD System. Matches the price you got for your list, and also you have an Overclockable board.
In terms of graphics, this CPU doesn't have integrated graphics. That does sound bad at first, but if you spend like 50 bucks on an used GPU, you'll have a smoother gaming Experience than on any IGPU. Linus has a Video on Cloud Gaming, I personally wouldn't recommend it, but if you want only a display out, you can go for a used GT710 or something like that, they go new for 50 bucks.
I don't really know, if the AIO will fit, but the liquid freezer II is one of the best performers.
This won't work.
Why? There is no gpu so this computer will not function.
As for the rest of the specs:
Board isn't great
Psu is a big no go for a 3060(ti)
Ssd is ok
Cpu is older
Ram is good funny how the whites are the cheapest for once
Case is good but by far not the smallest itx
Stock cooler will cool the cpu but it will run hot
Overall don't buy it if you don't have a gpu and just wait till you do. Psu 100% has to change for something better.
Get a b tier unit or better from the psu tier list I recommend a 600w or higher unit in b or a tier:
if this just build with "buy gpu later" not planning to play it without gp then its fine.
B550 or at least B450 tomahawk
you can check sabrent rocket for SSD. many others option as well
i highly reccomend 650W or at barely minimum 550W. something like Seasonic focus gold. Bequiet ( the newest) , CXM or TXM corsair . etc
  Spec: Macbook Air 2017
ProcessorPU: ii5 (I5-5350U |
| RAM: 8GB LPDDR3 |
| Storage: 128GB SSD
 | GPU: Intel HD 6000 |
| Audio: JBL 450BT Wireless Headset |
Solid. The Ryzen 5 5600x would be a really nice improvement and is the current CPU from AMD that replaced the 3600. Any thoughts there?
Ryzen 7 7800x3D -  Asus RTX4090 TUF OC- Asrock X670E Taichi - 32GB DDR5-6000CL30 - SuperFlower 1000W - Fractal Torrent - Assassin IV - 42" LG C2 - Windows 11 Pro
I checked the prices of the Ryzen 5 5600x and it is ~£60 more expensive than a 3600. is it still worth the upgrade?
That's up to you based on your use case after comparing benchmarks. Is this system for gaming? If so, at what resolution?
i think is matter since he used for game development and its rtx 30 series so i bet the 5600x would fully ultilize the GPU
i personally go for 5600X
| RAM: 8GB LPDDR3 |
| Storage: 128GB SSD
Threads merged. Please do not make multiple topics asking the same question. You can continue the discussion in this thread if you are still looking for build advice.
17 minutes ago, St0nl0y said:
I am going to use it at 1440p
It really comes down to personal preference but in the benchmarks I just looked at, its an choice to go 5600x. Its not quite as a dramatic difference between the two as it is with 1080p gaming but its still very noticeably faster. Buying a 3600 now is buying a 2 year old CPU.
Do you know if that case will fit a 120mm AIO and a standard PSU in it
It will. Only overly-long PSUs will have size issues, and I've made a few builds using the case with a 120mm radiator.
Primary PC:
PSU tier list
