Trouble with multiple displays not at their max refresh rate
MrReptilian
So i just bought a new 1440p 144Hz ASUS monitor, and so far it's been great, along with my RX580 i can play DOOM 2016 at like 120fps and such.
The problem arises when i setup my old (1080p 60Hz) alongside the new one, and since then, the new monitor is stuck at 100Hz, even if i change it to 144Hz if i leave the menu it just goes back to 100Hz. Now, after disconnecting my old monitor, i can use 144Hz no problem, so my question is, is my GPU too weak to handle both at their "max"? what card would be able to?
New monitor: ASUS TUF Gaming VG27WQ1B
Old monitor: Samsung T24C301
GPU: Sapphire RX580 4GB
are you using them through DP or HDMI?
My profile picure is real. That's what I look like in real life. I'm actually a blue and white African Wild Dog.
Ryzen 9 5900X - MSI Ventus 2x OC 3060 Ti - 2x8GB Corsair Vengeance LPX 3200MHz CL16 - ASRock B550 Phantom Gaming ITX/ax
EVGA CLC 280 + 2x140mm NF-A14 - Samsung 850 EVO 500GB + WD Black SN750 1TB - Windows 11/10 - EVGA Supernova G3 1000W
DP for the new 1440p one, HDMI for the old 1080p one (the old one only has 1 HDMI port)
I'm being shipped a 144hz monitor, and I was concerned about this sort of thing occurring as well. I'm very reliant on my second monitor for messaging/browsers even when I have a game up, or having a video run in the background.
