Here are Tom's Hardware Benchmarks of the 7850 in BF3.
http://www.tomshardware.com/reviews/radeon-hd-7870-review-benchmark,3148-6.html
Hope that helps!
- winny3141 :D
System Specs: AMD Phenom II X6 1100T Six-core CPU, AMD Radeon HD 6970 2 GB GDDR5 16X PCIe Video Card, MSI 890FXA-GD70 Motherboard, Kingston Hyper-X 1600 MHz RAM, ADATA 128 GB MLC SSD, 2 TB HDD, Astec Dual 120 mm closed Liquid cooling Loop, Cooler Master 800W Silent Pro Gold (80 Plus Gold Certified) PSU, Razer Black Widow Ultimate 2013 Gaming Keyboard (Love me my Cherry MX Blue Switches), a Razer Taipan Gaming Mouse (8200 dpi 4G sensor FTW!), Windows 7 Ultimate 64-bit
https://linustechtips.com/topic/13582-hd-radeon-7850/#findComment-146699
I have a Diamond Radeon HD 7850, FX 6100, and 16 Gigs of RAM @1600MHz
I run Far Cry 3 on High settings with no lag.
I think you'll be fine with High-Ultra on BF3 and BO2 with about a 30FPS.
You dont really need more than 30, but more is better!
 - Zalman Z11 Plus - ASRock Extreme3 970 AM3+ - FX 6100 @3.3GHz - 16GB Crucial Ballistix @1600MHz - Diamond Radeon HD 7850 2GB - Inland 600 Watt
-ADATA S510 SSD 120GB OS - 1TB WD Green for Storage - Westinghouse 26" TV (1920x1080) - Logitech K520 Mouse & Keyboard - Razer DeathAdder 2013 -
https://linustechtips.com/topic/13582-hd-radeon-7850/#findComment-146842
I have a 7850 2gb and I have played BF3 and BO2 all maxed out at 1680x1050 (not so far from 1080p) with excellent frames, but i havent played FC3 so I dont know how it will perform.
Mobo: Asus Maximus Impact VI Processor: Intel 4690K @ 4.4Ghz 1.22Vlts Memory: 2x8 GB DDR3 1866Mhz GSkill Sniper
VGA: Sapphire HD 7970 3GB OC Audio: Asus Impact Supreme FX SSD: Mushkin Chronos 120GB HDD: WD Black 500GB
Power Supply: Coolermaster V650 Semi Modular Case: Bitfenix Prodigy Cooling: Corsair H100i
https://linustechtips.com/topic/13582-hd-radeon-7850/#findComment-146936
BF3 yes far cry 3 no..I just sold my 7850 and got 2 7950s.I would play BF3 at 1080p on ultra and be in the 50s..But it all depends on the map also..
7950 xFire and only 50+fps? Did you check your gpu for any scaling issues or if xfire is enabled?
My single 7950 @ 1Ghz can easily get >60 for most times
Edit: Just realised you might not be running in 1080p lol
https://linustechtips.com/topic/13582-hd-radeon-7850/#findComment-148539
No I was saying I was getting 50 plus fps on my 7850 AT 1080P on ultra. My xfire 7950s get well over 120plus at 1080p.sorry I didn't clarify that.
https://linustechtips.com/topic/13582-hd-radeon-7850/#findComment-150759
While its expected for the 7850 not to go FULL TIT Ultra on games, there are plenty of users like you and I who do own such cards and can provide game settings info you should use.
The 7850 should play BF3 on Ultra (with 4xAA) easily, while it may not be 60fps and closer to 40fps, turning things down like 4XAA to 2XAA or Off,...everything @ medium and leaving Textures & Mesh on high, should see you comfy at near 60fps or above very easily.
Farcry 3, Run it in DX9 maxed out or DX11 On medium to high without AA
There are plenty of guides/review on how to get the most out of it, but you can always ask here ;)
Maximums - Asus Z97-K /w i5 4690 Bclk @106.9Mhz * x39 = 4.17Ghz, 8GB of 2600Mhz DDR3,.. Gigabyte GTX970 G1-Gaming @ 1550Mhz
https://linustechtips.com/topic/13582-hd-radeon-7850/#findComment-154906
1680x1050 BF3 on Ultra plays great. On 1080P I would say turing down AA a notch will be in order.
Antec 100, Msi 870 G45, Asus Xonar DGX, Creative Inspire T10 2.0, Creative Sound Blaster Tactic 3D, 4gb Corsair ram, Gigabyte HD 7850, AMD Phenom II x4 B55 @ 3.6Ghz, Cooler Master Hyper 212+, 500GB WD Caviar Black, Cooler Master RX 460, Samsung SyncMaster 226bw
https://linustechtips.com/topic/13582-hd-radeon-7850/#findComment-163056
Hope that helps!
- winny3141 :D
Them benchmark numbers are terrible. Ultra settings at 2560x1440, High settings @ 1080, Low settings @ 720P wtf LOL.
https://linustechtips.com/topic/13582-hd-radeon-7850/#findComment-163098
