Need some help deleting duplicate values in Excel
Go to solution Solved by mariushm,
Sort your table by the phone column
Add a column to the right of your data
Put a formula     = IF (  phonecolumn[ROWNUMBER]  <> phonecolumn[ROWNUMBER-1] , 0 ,1 )
Double click cell corner so that the formula is copy pasted / propagated all the way to the last row
Now the cells will have 1 if the phone number is identical to previous row's phone number.
So now you can enable filter on the top row (go on row, press Ctrl+Shift + L  or use the menu option)  and you can select only the rows with 1  (as in rows that have same number as previous row)
Now you can select the phone numbers (drag mouse over the cells or Shift + down / up ) and hit DELETE to erase cells
Disable filter to see your whole table again.
Hello, I have an excel sheet with duplicate phone numbers in a specific column. I want to keep the first number and delete the rest of it's duplicates without deleting it's rows or shifting up any of the cells. Any guidance to create a formula or some other method if any would be very helpful. Thanks.
2 minutes ago, Shammikit said:
This deletes entire rows
Step 1 says to select the range of cells that has the dupes.
Thanks
