NR200P cooling question
This was currently my plan (note: I am doing this twice because I am using my old parts to build a test system, then my daily driver to implement this again with a bit more confidence).
Test case: (i7-4790k, Asus H97i-PLUS)
Top of case mount: Glacier D120 at top of loop (Modified with G1/4 port on front side [now top side])
CPU: old corsair H110i pump repurposed for this
Bottom: old corsair 240mm rad refurbished
In this case, I currently lack a gpu until I upgrade two primary computers gpus. At that point it will get a EGVA 1060 6gb. I will then water cool it for fun.
Yes, am tearing apart a H110i (and a H60) to play around with them for this.
Final case: (i7-9700f, Unknown board)
CPU: Bykski pump combo on CPU
Bottom: XSPC TX240 with 2x nf a2x15 chromax
I will probably be water cooling the gpu when I get an upgrade. Note: that 1060 is currently the primary card in this.
I will end up moving this to build section when I get to that point.
