Temps hot on Modern Warfare high settings?
Xolin
CPU: Ryzen 5 3600 with Be Quiet! Pure Rock Slim 2 ; 1.250V
GPU: MSI RTX 2060 VENTUS
I'm running modern warfare on high settings. My GPU temps are around 84C and CPU temps are at around 73C.
Any help on adjusting settings?
Thanks.
8 minutes ago, Xolin said:
-snip-
I mean yeah that's a little hot, when's the last time you change the thermal paste on you're GPU?
The geek himself.
What Kind of Case? Case airflow makes a big difference.
Also did you just put this together or did you notice the temps a while after building?
What do you mean?
84 is fine temps, don’t worry unless it’s throttling.
if it’s like a lot of gpus it would be pretty quiet until it gets HOT (or In my gpus case, will cook itself and just turn off, seriously Amd, 95c shouldn’t be 50% fans), you can adjust the fan curves with MSI AB
I could use some help with this!
please, pm me if you would like to contribute to my gpu bios database (includes overclocking bios, stock bios, and upgrades to gpus via modding)
Bios database
My beautiful, but not that powerful, main PC:
prior build:
1 hour ago, HelpfulTechWizard said:
What do you mean?
I had a single fan on my rtx 2060 when I had it and only hit 75 tops. I feel that's a little hot. Unless his fan settings aren't optimal or there is no air flow in the case.
The geek himself.
The GPU was purchased on 10/2019 and I think the thermal paste has not changed.
The rest of the computer is brand new.
 Antec P6 with one rear fan.
Found your issues.
no from intake airflow, that gpu is right up against the psu shround, it can’t breathe
Bios database
prior build:
