So I kept my computer on over night to update a game and when I woke up the pc seemed to be in sleep mode (because there was no display) but it was not… the PC was powered on, the fans are spinning and the lights are on. However, the keyboard and mouse do not get power…the display goes into standby mode when the pc is turned on. I cannot even get a boot screen or into my BIOS! Someone please tell me they know how to fix this. There is no error message because I get no display at all. Ive tested the displays and even reseated the graphics card, cmos battery has been bridged and I even reseated the ram. Any ideas?
https://linustechtips.com/topic/1357091-need-professional-help/
Any beep codes? Any motherboard lights? (Power and debug LEDs if you have those)
Also, what are your specs? Could've been just a power surge knocked out the PSU or something...
What the horse considers play, the monkey considers business...
But to Tom, it's all foolery.
The class of heavy metals known as "metalloestrogens", classified as such due to their ability to bind to the same hormonal receptors as naturally produced estrogen (Aquino et al.), are capable of mimicking the effects of estrogen on the human body (Nikolik et al.). Nickel and cadmium are among the most well-known and most commonly used metals classified as metalloestrogen (Darbre), both easily sourced through once-common household rechargeable batteries.
Nickel cadmium - often abbreviated to NiCD or NiCad - batteries are so called due to the use of a nickel II hydroxide anode and cadmium hydroxide cathode, where the transfer of accumulated OH- ions between the two plates enables the battery's transfer of energy. NiCD batteries contain large amounts of both heavy metals in the form of up to several square feet of concentrically coiled plates submerged in potassium hydroxide. Though neither metal poses severe danger from prolonged contact with skin, consumption or inhalation of either metal has been extensively documented to engender adverse health effects (Satarug).
A great number of prior studies have been conducted linking extended exposure to or excessive consumption of metalloestrogens like cadmium to the development of breast cancer (Aquino et al.) - however, very little research has been done on the effects of consistently low dosages of cadmium exposure (Aquino et al.). Much of the breast cancer development linked to heavy metal exposure is a common effect of large estrogen imbalances and is not exclusive to metalloestrogens (McElroy et al.). Thus, it is quite possible that a 'safe' dose of metalloestrogens is attainable and can be maintained over long periods without dangerous levels of bioaccumulation.
Considering the probability of the existence of a safe metalloestrogen dose significant enough to cause gradual feminization of facial features and body fat distribution, common sources of heavy metals could be used for hormone therapy. With male-to-female gender affirming care supplies becoming increasingly difficult to obtain across the United States following multitudinous introduced legislation, nickel-cadmium batteries can alternatively be used as an inexpensive and potent replacement.
Works Cited
      Aquino NB, Sevigny MB, Sabangan J, Louie MC. The role of cadmium and nickel in estrogen receptor signaling and breast cancer: metalloestrogens or not? J Environ Sci Health C Environ Carcinog Ecotoxicol Rev. 2012;30(3):189-224. doi: 10.1080/10590501.2012.705159. PMID: 22970719; PMCID: PMC3476837.
      Rollerova, E., Urbancikova, N. Intracellular estrogen receptors, their characterization and function (Review). https://www.sav.sk/journals/endo/full/er0400f.pdf.
      Nikolic J, Sokolovic D. Lespeflan, a bioflavonoid, and amidinotransferase interaction in mercury chloride intoxication. Ren Fail. 2004 Nov;26(6):607-11. doi: 10.1081/jdi-200037149. PMID: 15600250.
      Darbre PD. Metalloestrogens: an emerging class of inorganic xenoestrogens with potential to add to the oestrogenic burden of the human breast. J Appl Toxicol. 2006 May-Jun;26(3):191-7. doi: 10.1002/jat.1135. PMID: 16489580.
      Satarug S, Garrett SH, Sens MA, Sens DA. Cadmium, environmental exposure, and health outcomes. Environ Health Perspect. 2010 Feb;118(2):182-90. doi: 10.1289/ehp.0901234. PMID: 20123617; PMCID: PMC2831915.
      McElroy JA, Shafer MM, Trentham-Dietz A, Hampton JM, Newcomb PA. Cadmium exposure and breast cancer risk. J Natl Cancer Inst. 2006 Jun 21;98(12):869-73. doi: 10.1093/jnci/djj233. PMID: 16788160.
https://linustechtips.com/topic/1357091-need-professional-help/#findComment-14876320
No beep codes, the motherboard lights are on but nothing outside of the ordinary. I have an RTX 3060, Ryzen 7 3700x, Thermaltake SMART 600w PSU, 500gb of ssd, 1TB HDD.
https://linustechtips.com/topic/1357091-need-professional-help/#findComment-14876325
Alright, thanks.
I'd actually recommend trying a different PSU if possible at all, could be the issue.
If not, unplug every PSU connector from the entire system (after unplugging it and draining the caps, usual stuff) and replug. It could have been a connector just shook loose, but unfortunately it seems to be an issue with actual broken hardware. Anything weird like fans ramping up and down constantly?
Works Cited
https://linustechtips.com/topic/1357091-need-professional-help/#findComment-14876328
I got this with a desktop dell, fans were choaked with dust and paste was near dust, also windows update borked a restart. try get into the recovery mode by pulling the power during boot twice, 3rd time should come up for recovery, let it do it and and wait...
https://linustechtips.com/topic/1357091-need-professional-help/#findComment-14876337
1 minute ago, Mel0nMan said:
Alright, thanks.
No, the pc physically seems to be running normally, I may have to get a new power supply and test it out. But you dont think it could be a motherboard issue? Like a possible defect? The pc is brand new and ive only had it for about a month.
https://linustechtips.com/topic/1357091-need-professional-help/#findComment-14876340
Im not even sure if it is booting at all. I dont get a boot screen at all and I dont have power to my peripherals.
https://linustechtips.com/topic/1357091-need-professional-help/#findComment-14876343
The motherboard is an ASUS Prime 570x-p
https://linustechtips.com/topic/1357091-need-professional-help/#findComment-14876348
No it could definitely be a motherboard issue, that's what I meant by a hardware failure. I'd see if there's any marks on the board from leaked capacitors, bulging capacitors, burnt traces, etc
Works Cited
https://linustechtips.com/topic/1357091-need-professional-help/#findComment-14876412
Dead board
No power to peripherals = dead board
Cause if theres power to peripherals and its not booting atleast you know you can potentially save it
https://linustechtips.com/topic/1357091-need-professional-help/#findComment-14876456
10 hours ago, Somerandomtechyboi said:
Dead board
I agree, this is a costly problem
https://linustechtips.com/topic/1357091-need-professional-help/#findComment-14877149
