RX580 Power Cable Burnt? I replaced PSU, is my GPU okay?
By
Edgrd
in Power Supplies
in Power Supplies
Solved by LauriHimself,
29 minutes ago, Edgrd said:the pcie cable burns itself
as is ran ok the last time your gpu is probably fine.
you REALLY want to clean the pcie connector on the gpu thoroughly. having dirt, residue or anyththing in there can cause little arcs that melt the connector (likely what happened before)
Featured Topics
ClumsyMonster244 ·
Posted in Troubleshooting0 -
VirusDumb ·
Posted in Looking For Group0 -
Gat Pelsinger ·
Posted in Linux, macOS and Everything Not-Windows1 -
3
Sai125943 ·
3
eric_s ·
Posted in Troubleshooting2 -
Bublito ·
Posted in Troubleshooting3 -
3
1
