Unable to Extend Volume after System Image Restored
Solved by Murasaki,
I think its not letting you because they're not in the right order. Unallocated space needs to be adjacent to the target volume you want to extend (like right after it with no other paritions in the way). In your case its before it and in between so thats.. far from ideal.. Not sure if creating extra partitions or swapping letters will align them better... need to be doing that myself to figure it out. Windows' disk managment tools have limitations and I see EaseUS' parition manager didn't do the job for you... then maybe try a live usb of GParted. It supports managing Windows volumes and might be more flexible.
Of course I would like to mention to have backups on hand before performing such operations.
