So, after much deliberation, I've decided that I'd rather save some money than spend on what would be a £400+ custom W/C loop. I've started looking into the NZXT Kraken G10 paired with a H105 for cooling my GPU, and then either another H105 or a Swiftech H320 for the CPU? These will all be going into a Switch 810 which is why I have gone for the sizes I have.
So, I've summed my options up into a poll for you fine people.
CPU: 5930K @ 4.5GHz | GPU: Zotac GTX 980Ti AMP! Extreme edition @ 1503MHz/7400MHz | RAM: 16GB Corsair Dom Plat @ 2667MHz CAS 13 | Motherboard: Asus X99 Sabertooth | Boot Drive: 400GB Intel 750 Series NVMe SSD | PSU: Corsair HX1000i | Monitor: Dell U2713HM 1440p monitor
https://linustechtips.com/topic/135651-cpu-gpu-loops-with-aio/
H105 cpu and H90 gpu
Corsair 400C- Intel i7 6700- Gigabyte Gaming 6- GTX 1080 Founders Ed. - Intel 530 120GB + 2xWD 1TB + Adata 610 256GB- 16GB 2400MHz G.Skill- Evga G2 650 PSU- Corsair H110- ASUS PB278Q- Dell u2412m- Logitech G710+ - Logitech g700 - Sennheiser PC350 SE/598se
Is it just me or is Grammar slowly becoming extinct on LTT?
https://linustechtips.com/topic/135651-cpu-gpu-loops-with-aio/#findComment-1804270
What GPU needs a h105?
What GPU needs a custom loop?
https://linustechtips.com/topic/135651-cpu-gpu-loops-with-aio/#findComment-1804273
Honestly, it would be much better to just stick with air cooling for the GPU or save up for a custom loop.
NZXT Phantom|FX-8320 @4.4GHz|Gigabyte 970A-UD3P|240GB SSD|2x 500GB HDD|16GB RAM|2x AMD MSI R9 270|2x 1080p IPS|Win 10
Dell Precision M4500 - Dell Latitude E4310 - HTC One M8
$200 Volvo 245
https://linustechtips.com/topic/135651-cpu-gpu-loops-with-aio/#findComment-1804277
From the above options only. I'm filling up a Switch 810 so a H90 would look icky.
https://linustechtips.com/topic/135651-cpu-gpu-loops-with-aio/#findComment-1804278
I'd have the money for a custom loop by the time I build this, I'd just rather not spend double the amount when I could achieve similar results with AIOs.
https://linustechtips.com/topic/135651-cpu-gpu-loops-with-aio/#findComment-1804286
I think I'll just sit this one out
Need is the wrong word to use in the water cooling section. ;) I have a Switch 810, and I'd like to fill it up as much as possible.
https://linustechtips.com/topic/135651-cpu-gpu-loops-with-aio/#findComment-1804287
I'm getting at the fact that no GPU will need more than a thick 120mm at most.
Just put the GPU on the bottom intake or rear exhaust or something.
Error: 410
https://linustechtips.com/topic/135651-cpu-gpu-loops-with-aio/#findComment-1804296
But it's much cooler and better for a custom loop. When did anyone say an AIO has the same performance as a custom loop? Plus most GPU blocks have VRAM cooling which (If I'm correct) the Kraken doesn't.
$200 Volvo 245
https://linustechtips.com/topic/135651-cpu-gpu-loops-with-aio/#findComment-1804299
Nobody said they perform the same. That's why I said *similar* What I'm trying to get at is the price difference between an AIO set up and a custom loop isn't worth the temperature difference.
That was something I was going to ask about with the Kraken, as far as I know it only has a single 80mm fan blowing onto the VRAM? That doesn't sound adequate...I haven't heard any complaints about it though.
https://linustechtips.com/topic/135651-cpu-gpu-loops-with-aio/#findComment-1804323
I've seen a few complaints http://www.pugetsystems.com/labs/articles/NZXT-Kraken-G10-Review-527/#UnigineHeavenPro4_0Temperature&NoiseLevels http://www.pcper.com/reviews/Graphics-Cards/Using-NZXT-Kraken-G10-Watercool-Radeon-R9-290/Performance-Results
However, as Pcper points out you can just get a few heatsinks for the VRM. http://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Daps&field-keywords=vrm+heatsink&tag=pcper04-20&tag=pcper04-20
OR something I want to try with my 780 is velcroing or taping a 120mm fan onto the g10.
CPU: 5820k 4.5Ghz 1.28v, RAM: 16GB Crucial 2400mhz, Motherboard: Evga X99 Micro, Graphics Card: GTX 780, Water Cooling: EK Acetal CPU/GPU blocks,
240mm Magicool slim rad, 280mm Alphacool rad, D5 Vario pump, 1/4 ID 3/4 OD tubing, Noctua Redux 140/120mm fans. PSU: Evga 750w G2 SSD: Samsung 850 Pro 256GB & Seagate SSHD 2TB Audio: Sennheiser HD558s, JBL! speakers, Fiio E10k DAC/Amp Monitor: Xstar DP2710LED @ 96hz (Korean Monitor) Case: Fractal Node 804
https://linustechtips.com/topic/135651-cpu-gpu-loops-with-aio/#findComment-1804382
So would I just use thermal adhesive to attach those to the GPU? Sounds like an easy fix.
You think a larger 120mm fan will make a significant difference?
https://linustechtips.com/topic/135651-cpu-gpu-loops-with-aio/#findComment-1804437
At the very least 120mm moves more air with the same or less noise. Not sure how much it would help. Possibly couple it with VRM aftermarket heatsinks?
https://linustechtips.com/topic/135651-cpu-gpu-loops-with-aio/#findComment-1804442
True, I forgot that any fan 80mm or smaller tend to suffer from whining noises at higher RPMS. It's just a little irritating that it won't look the most elegant solution. I think I'll try just the Heat sinks first and see what m temperatures are like then. If they're high enough to make me uncomfortable then I'll find a way to ghetto strap a 120mm fan to it.
https://linustechtips.com/topic/135651-cpu-gpu-loops-with-aio/#findComment-1804457
Have you thought about doing something like adding a loop for the GPU, and buying a h220/h320 for the CPU then adding in another 240?
I think more GPU's deserve watercooling IMO.  The benefits of watercooling a GPU far outweigh the benefits of watercooling a CPU (custom loop or not)
Air coolers like the nh-d14 are basically silent, but I have yet to see a review of a GPU with a reference or non-reference design that is "silent"
Taking a CPU from 60-80C to 50-70c with a custom loop doesn't make much sense to spend like 400$ on a custom loop just for the CPU (I see people do this all the time and I'm so confused)
Doing a custom loop or g10 for a GPU makes so much more sense in my eyes, you go from 65-85C to 35-55c (depending on the loop+rad space+fans)
@helping the rad size is a bit dependant on the fan speeds you wish it to run at too, a 240mm rad for a single GPU could easily have 40-60% fan speeds vs the 60-75% of a 120mm  ( and I think we can both agree, quieter is always better :D )
https://linustechtips.com/topic/135651-cpu-gpu-loops-with-aio/#findComment-1804552
Tell me how it goes! I'm honestly quite curious. I'd love to watercool my GPU to keep it quieter but is it worth the expense and (imo) a bit worse aesthetic? We'll see.
https://linustechtips.com/topic/135651-cpu-gpu-loops-with-aio/#findComment-1804576
No, a single 120mm AIO cooler will do plenty fine cooling a 7950.
Ramping fans will only have so big of an affect, a GPU under any arbitrary 120mm AIO with a decent fan, at say, 30%, will hit voltage limitations before temperature becomes an issue.
Error: 410
https://linustechtips.com/topic/135651-cpu-gpu-loops-with-aio/#findComment-1804601
Exactly. I love the Stock Nvidia blower coolers, but they're definitely not quiet! I don't mind the look of the NZXT. G10 though. It's not ugly, and the bigger your case, the more room you have to route tubing more discretely and make a feature of the white metal bracket.
https://linustechtips.com/topic/135651-cpu-gpu-loops-with-aio/#findComment-1804617
This won't be for my 7950. Gawd, I'd have to be mad to water cool a card with a TRIPLE SLOT DCUII cooler on it. with fans @ 40% it never goes about 50 degrees centigrade at full load. No, this is going to be for my future GPU, when the 800 series come out. The equivalent to the 780 Ti.
https://linustechtips.com/topic/135651-cpu-gpu-loops-with-aio/#findComment-1804619
If an X40 can handle a 290X with plenty of room to spare, the limit of your noise will be measured by the VRM fan on the bracket rather than the AIO.
You didn't specify, but it doesn't really change anything.
regardless, it's your choice anyway so do as you please.
Error: 410
https://linustechtips.com/topic/135651-cpu-gpu-loops-with-aio/#findComment-1804626
Sorry about not specifying. Choosing the H105 was more about aesthetics than functionality, if I'm honest.
https://linustechtips.com/topic/135651-cpu-gpu-loops-with-aio/#findComment-1804677
if you do that just be sure to invest in a decent 80/92mm whatever fan and short sinks for the VRM as stated before.
The fans on the h105 won't matter since you can just leave them at 5v
Error: 410
https://linustechtips.com/topic/135651-cpu-gpu-loops-with-aio/#findComment-1804684
Like these?
http://www.amazon.com/Cosmos-Copper-Cooling-Heatsinks-cooler/dp/B00637X42A/ref=sr_1_2?ie=UTF8&qid=1396655317&sr=8-2&keywords=vrm+heatsink
https://linustechtips.com/topic/135651-cpu-gpu-loops-with-aio/#findComment-1804689
