Most powerful blower card?
Solved by RollinLower,
11 minutes ago, Mel0nMan said:Are there any of those? Checking TechPowerUp looks like no... Plus I don't need that performance for what I do.
Edit: they aren't listed basically anywhere, they're mostly OEM cards but yes they exist.
Thank you for the recommendation, I may go for those.
i had two blower regular 2080's in a previous rig, ASUS RTX 2080 Turbo and Zotac RTX 2080 Gaming. also the GPU in my F@H server is a blower RTX 2080Ti. But that has a waterblock now. The little blower cooler was just not nearly enough for such a card.
i believe the ASUS Turbo line even has RTX 3090's, but i really doubt the performance would be on par with a 3090 with a better cooler.
