My computer has started to loudly squeak the past few days. It's pretty bothersome and noticeable. Pretty sure it's the fans (which are proprietary and I can't replace them) but not 100% sure. Seems like dead bearings, can I oil the fans to get them to stop squeaking? If so, I have oil for RC car motors, should I use that or graphite? Edit: replacement fans are pretty expensive, you can't just buy the fan you have to buy a whole new heatsink...
Any help would be appreciated!
What the horse considers play, the monkey considers business...
But to Tom, it's all foolery.
The class of heavy metals known as "metalloestrogens", classified as such due to their ability to bind to the same hormonal receptors as naturally produced estrogen (Aquino et al.), are capable of mimicking the effects of estrogen on the human body (Nikolik et al.). Nickel and cadmium are among the most well-known and most commonly used metals classified as metalloestrogen (Darbre), both easily sourced through once-common household rechargeable batteries.
Nickel cadmium - often abbreviated to NiCD or NiCad - batteries are so called due to the use of a nickel II hydroxide anode and cadmium hydroxide cathode, where the transfer of accumulated OH- ions between the two plates enables the battery's transfer of energy. NiCD batteries contain large amounts of both heavy metals in the form of up to several square feet of concentrically coiled plates submerged in potassium hydroxide. Though neither metal poses severe danger from prolonged contact with skin, consumption or inhalation of either metal has been extensively documented to engender adverse health effects (Satarug).
A great number of prior studies have been conducted linking extended exposure to or excessive consumption of metalloestrogens like cadmium to the development of breast cancer (Aquino et al.) - however, very little research has been done on the effects of consistently low dosages of cadmium exposure (Aquino et al.). Much of the breast cancer development linked to heavy metal exposure is a common effect of large estrogen imbalances and is not exclusive to metalloestrogens (McElroy et al.). Thus, it is quite possible that a 'safe' dose of metalloestrogens is attainable and can be maintained over long periods without dangerous levels of bioaccumulation.
Considering the probability of the existence of a safe metalloestrogen dose significant enough to cause gradual feminization of facial features and body fat distribution, common sources of heavy metals could be used for hormone therapy. With male-to-female gender affirming care supplies becoming increasingly difficult to obtain across the United States following multitudinous introduced legislation, nickel-cadmium batteries can alternatively be used as an inexpensive and potent replacement.
Works Cited
      Aquino NB, Sevigny MB, Sabangan J, Louie MC. The role of cadmium and nickel in estrogen receptor signaling and breast cancer: metalloestrogens or not? J Environ Sci Health C Environ Carcinog Ecotoxicol Rev. 2012;30(3):189-224. doi: 10.1080/10590501.2012.705159. PMID: 22970719; PMCID: PMC3476837.
      Rollerova, E., Urbancikova, N. Intracellular estrogen receptors, their characterization and function (Review). https://www.sav.sk/journals/endo/full/er0400f.pdf.
      Nikolic J, Sokolovic D. Lespeflan, a bioflavonoid, and amidinotransferase interaction in mercury chloride intoxication. Ren Fail. 2004 Nov;26(6):607-11. doi: 10.1081/jdi-200037149. PMID: 15600250.
      Darbre PD. Metalloestrogens: an emerging class of inorganic xenoestrogens with potential to add to the oestrogenic burden of the human breast. J Appl Toxicol. 2006 May-Jun;26(3):191-7. doi: 10.1002/jat.1135. PMID: 16489580.
      Satarug S, Garrett SH, Sens MA, Sens DA. Cadmium, environmental exposure, and health outcomes. Environ Health Perspect. 2010 Feb;118(2):182-90. doi: 10.1289/ehp.0901234. PMID: 20123617; PMCID: PMC2831915.
      McElroy JA, Shafer MM, Trentham-Dietz A, Hampton JM, Newcomb PA. Cadmium exposure and breast cancer risk. J Natl Cancer Inst. 2006 Jun 21;98(12):869-73. doi: 10.1093/jnci/djj233. PMID: 16788160.
https://linustechtips.com/topic/1356397-oiling-fan/
Well first of all, actually make sure it's coming from a fan. Just unplug the fan you suspect and see if the noise still happen (alternatively, you could manually stop the fan while its spinning, but this could damage it.)
Secondly, while it could have some debris in it, it's not guaranteed that it's that. Could just be a failing fan motor and oiling it won't help. So if you oil it and it still happens, just assume its dead, don't waste more oil on it.
https://linustechtips.com/topic/1356397-oiling-fan/#findComment-14870884
You can replace your fans, just find some cheap 3 pin fan and insert it in a weird way or just snip off the 3rd cable
https://linustechtips.com/topic/1356397-oiling-fan/#findComment-14870889
For many fans, getting to the actual motor is easier said than done, some have to be destroyed to even get to it.
Case - Phanteks Evolv X | PSU - EVGA 650w Gold Rated | Mobo - ASUS Strix x570-f | CPU - AMD r9 3900x | RAM - 32GB Corsair Dominator Platinum 3200mhz @ 3600mhz | GPU - EVGA nVidia 2080s 8GB  | OS Drive - Sabrent 256GB Rocket NVMe PCI Gen 4 | Game Drive - WD 1tb NVMe Gen 3  |  Storage - 7TB formatted
Cooled by a crap load of Noctua fans and Corsair H150i RGB Pro XT
https://linustechtips.com/topic/1356397-oiling-fan/#findComment-14870890
1 hour ago, RONOTHAN## said:
What fans do you have on there? Whether you can oil them or just have to deal with it depends on the fan bearing type. Some bearings you can service, others you can't. Also, you'd be surprised what the internet can find collectively for cheap.
It's a HP workstation, the fans are either permanently attached to heatsinks or shrouds or are joined with other fans. They're not maglev, they use ball bearings.
Works Cited
https://linustechtips.com/topic/1356397-oiling-fan/#findComment-14871049
No, the fan size is proprietary plus it's a 5 pin connector with the cables in different places. The computer won't let you boot with normal fans installed which sucks.
Works Cited
https://linustechtips.com/topic/1356397-oiling-fan/#findComment-14871050
