Unifi Vintage Hardware, no way to adopt?
Nocturn
I am currently in the process  of setting up a new wifi solution in my apartments with seamless roaming, while I am waiting for the hardware to arrive, I was using my old UAP-ACv2 from ubiquity.
Due to some issue I had to factory reset it, and now I don't know how to adopt it.
Controllers of the version 5.6.xxx don't want to start, while the newer controller is missing the adopt button, what should I do?
To be clear, is this AP square shaped? If it is, then 5.6.x is your only option - that has been removed from the controllers since then.
Looking to buy GTX690, other multi-GPU cards, or single-slot graphics cards:
Yes, it is.
i was able to make it work, but I am unable to login into the controller, is there any way to bypass the login?
(gives wrong password/username error)
1 hour ago, Oblivion_Creature said:
Yes, it is.
You can try this (at your own risk, I haven’t tested this, make sure to have a backup): https://community.ui.com/questions/How-to-recover-access-to-a-unifi-controller-when-the-admin-password-has-been-lost-/bea32e54-c8cd-4d08-ba98-b836acebfeb4
