Budget (including currency): $2000 AUD/1448 usd
Country: Australia
Games, programs or workloads that it will be used for: Minecraft, Gta, BeamngDrive and forza
is there any way I could improve
image.thumb.png.cfd1ef73e18ab9da36fece7d1d659e32.pngimage.png.abf02bf9ff42b93f87a14d18e5a78650.png
https://linustechtips.com/topic/1356230-first-pc-build/
I wouldn't pay twice what the graphics card is worth, but if you see that as worth it then go for it. Other than that, you need a Z series motherboard to overclock. Otherwise you might as well get a locked CPU instead of the unlocked one. I'd also get a better CPU cooler; Noctua is usually a good bet. No storage?
Above all, get a better PSU; don't spend that kind of money and power it with trash. Look at the LTT Tier List, pick something from the top two categories.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/1356230-first-pc-build/#findComment-14869791
