You willing to give an example?
(Do know you can make a Youtube link such that it jumps to a certain time (Use the share option then select "start at")
But ive not heard what you described.
When i ask for more specs, don't expect me to know the answer!
I'm just helping YOU to help YOURSELF!
(The more info you give the easier it is for others to help you out!)
Not willing to capitulate to the ignorance of the masses!
https://linustechtips.com/topic/1355219-jayztwocents-audio/#findComment-14862545
i usually watch jayztwocents wiht speakers and I see no issue with his audio on his videos.
however it is likely that has to do with the audio encoder they use or something like that if you still ask me but as I said I see no issues even in speaker mode.
Make sure to quote me if you want me to respond
Turn your Mobile VR or PSVR Headset into a working 6DoF SteamVR one guide/tutorial (below):
My PC
https://linustechtips.com/topic/1355219-jayztwocents-audio/#findComment-14862548
For a second I thought this was a copy/replace/paste of
Just watched his latest video and as the others said I don't notice anything like nails on chalkboard or the likes on my speakers.
Crystal: CPU: i7 7700K | Motherboard: Asus ROG Strix Z270F | RAM: GSkill 16 GB@3200MHz | GPU: Nvidia GTX 1080 Ti FE | Case: Corsair Crystal 570X (black) | PSU: EVGA Supernova G2 1000W | Monitor: Asus VG248QE 24"
Laptop: Dell XPS 13 9370 | CPU: i5 10510U | RAM: 16 GB
Server: CPU: i5 4690k | RAM: 16 GB | Case: Corsair Graphite 760T White | Storage: 19 TB
https://linustechtips.com/topic/1355219-jayztwocents-audio/#findComment-14863068
