My current build is as follows:
I5-9600K CPU
RX 6900 XT GPU
16GB DDR4 3000mhz RAM
Asus Z390 Strix Motherboard
850W EVGA G2 PSU
I'm playing on 2.5K Ultrawide
I'm pretty sure my CPU is still bottlenecking me a bit even on that resolution.
Faster RAM might make a difference, but I doubt the investment is really worth it.
SO I'm thinking at upgrading my CPU down the line, the easiest option would be to add a 9700k or a 9900k without having to replace my motherboard
On the other hand there are a few generation out now So I'm wondering if it's worth it to just get a new motherboard/CPU combo
I can't really say if I have a budget for this, but I'm usually someone who looks for the best value
So what are my options? I've always stuck with Nvidia/Intel but with the market as it is, I've now purchased my first AMD product
Keeping in mind, I only game on my PC, no rendering, or any other software.
https://linustechtips.com/topic/1355023-upgrade-path-probably-cpu/
I5-9600K CPU
RX 6900 XT GPU
850W EVGA G2 PSU
have you overclocked the cpu and before doing that what is your cooler
Main:
  • CPU
    10700k 5ghz All core 47 ring ratio 1.275v
  • Motherboard
    MSI Z590 A Pro
  • RAM
    4x8 viper steel samsung bdie: 4200-17-17-30
  • GPU
    Gigabyte RTX 3080 Gaming Oc
  • Case
    O11 air mini
  • Storage
    970 Evo Plus 500gb OS, Sn550 1tb, 860 evo 500gb, 2tb MX500
  • PSU
    RM750x (2018)
  • Display(s)
    Acer Nitro vg272up, Kogan 24 1080 120hz
  • Cooling
    arctic 280aio, EK M.2 NVMe Heatsink on 970 evo plus
    Second:
    Cpu: i5-8400
    Cooling: ID-Cooling Frostflow 120x
    Ram: 2x8gb 2666 c16 hyperx fury, tuned the absolute balls out of it but def not stehble.
    Mobo: Asus Prime H310M-K
    Gpu: Igpu
    Case: Coolermaster MB311L
https://www.cpuagent.com/fps-bottleneck-calculator
I used this site a couple of times to check for system bottlenecks. I put in your system specs and it shows you an upgraded version of your system below to compare performance.
https://www.cpuagent.com/build-compare/intel-core-i5-9600k-vs-intel-core-i9-10900k/summary/amd-radeon-rx-6900-xt-vs-amd-radeon-rx-6900-xt?res=4-vs-4&quality=ultra-vs-ultra&ram=16-vs-32&ramspeed=3000-vs-3800
Your 6900xt is definitely limited by your 9600k.
IMO don't get a 9700k it won't be much better than your 9600k, step all the way up to a 9900k.
Many games prefer 12 threads and the 9700k only has 8. The 9900k has 16.
A 9900k is basically a 10700, no need to upgrade your Strix board IMO.
I don't overclock my CPU, nor do I plan to, I did so with my previous CPU and ended up killing the motherboard prematurely.
So basically other than boost clocks I quit OCing.
My cooler is the noctua NH-D15.
I mean if your cpu dosent reach 85% in games its fine but the more more ghz the better it handles with high end gpus also the only way you would kill somethimg is by putting something like 1.5v to the cpu anything under 1.45 is the safe zone im sure you can try a lil oc cuz putting like 17ghz on a cpu it wont boot but there is no harm because theres not enough voltage so if you try ocing dont go over 1.45 volts and youll be fine
Main:
  • CPU
  • Motherboard
    MSI Z590 A Pro
  • RAM
  • GPU
  • Case
    O11 air mini
  • Storage
  • PSU
    RM750x (2018)
  • Display(s)
  • Cooling
    Second:
    Cpu: i5-8400
    Gpu: Igpu
As others have said, aim for a 9900k. Also you're leaving some performance on the table with that D15 and no overclocking.
A RAM upgrade would probably be nice too. 3000mhz RAM isn't exactly quick. A faster set of sticks, maybe with some OCing and tightening timings, will help your system out. You might be able to OC your current RAM as well.
