2 minutes ago, _Kiko_ said:
So i bought a new laptop and updated the drivers and that things and then i disabled the battery boost option but it was still limiting my fps at 30 so if someone knows how to disable this at 100% please help me
(Sorry if i made any error Im from Portugal)
what gpu and cpu does it have? and is it plugged in
Main:
  • CPU
    10700k 5ghz All core 47 ring ratio 1.275v
  • Motherboard
    MSI Z590 A Pro
  • RAM
    4x8 viper steel samsung bdie: 4200-17-17-30
  • GPU
    Gigabyte RTX 3080 Gaming Oc
  • Case
    O11 air mini
  • Storage
    970 Evo Plus 500gb OS, Sn550 1tb, 860 evo 500gb, 2tb MX500
  • PSU
    RM750x (2018)
  • Display(s)
    Acer Nitro vg272up, Kogan 24 1080 120hz
  • Cooling
    arctic 280aio, EK M.2 NVMe Heatsink on 970 evo plus
    Second:
    Cpu: i5-8400
    Cooling: ID-Cooling Frostflow 120x
    Ram: 2x8gb 2666 c16 hyperx fury, tuned the absolute balls out of it but def not stehble.
    Mobo: Asus Prime H310M-K
    Gpu: Igpu
    Case: Coolermaster MB311L
1 minute ago, _Kiko_ said:
I have an i7 10750h RTX 2060 and 16gb ram it only limits when Im not plugged in
yeah the thing with laptops it limits or maybe even disable the dedicated gpu/2060 so it might be using the igpu of your cpu the reason is that laptop battery will drain and hurt the battery performance with all the heat and drainage so it makes all the compoments slower to cool the battery and to save the battery from dying
Main:
  • CPU
  • Motherboard
    MSI Z590 A Pro
  • RAM
  • GPU
  • Case
    O11 air mini
  • Storage
  • PSU
    RM750x (2018)
  • Display(s)
  • Cooling
    Second:
    Cpu: i5-8400
    Gpu: Igpu
Oh okay so it means that when Im plugged in its for gaming and when Im not its for work and that right?
thats correct
Main:
  • CPU
  • Motherboard
    MSI Z590 A Pro
  • RAM
  • GPU
  • Case
    O11 air mini
  • Storage
  • PSU
    RM750x (2018)
  • Display(s)
  • Cooling
    Second:
    Cpu: i5-8400
    Gpu: Igpu
Okay thank you 🙂
np 🙂
Main:
  • CPU
  • Motherboard
    MSI Z590 A Pro
  • RAM
  • GPU
  • Case
    O11 air mini
  • Storage
  • PSU
    RM750x (2018)
  • Display(s)
  • Cooling
    Second:
    Cpu: i5-8400
    Gpu: Igpu
